Steering Knuckle Torque Specs
Does anyone know the torque specs for any of the following :
1) Hub assembly bolts to steering knuckle
2) Ball joint pinch bolt
3) Strut bolts to knuckle
4) Ball joint castle nut
5) Tie rod end castle nut
6) Front control arm rear bolt
7) Front control arm "middle" bolt
Can anyone confirm these specs :
1) Axle nut : 137 ft-lbs
2) Caliper to mount : 20 ft-lbs
3) Caliper mount to knuckle : 59 ft-lbs
Thanks!
  • 6 years later...
Grave dig, any torque specs for rear suspension 05 to 09 please?
Thank you!
joe r
http://people.csail.mit.edu/ilh/vacation/
You'll find them in those.
Engine Build - Click Here
  • 4 years later...
