Angelo23 Posted August 6, 2018 Share Posted August 6, 2018 Hello everyone, the drivers side power seat moves up and down, but will not move front and back. I assume the problem is a blown fuse, so i took out the manual and looked up the fuse location section (it's section 12-6 in the manual)... and the fuse responsible for moving the seat forward/back is not shown. I looked at the section twice just to make sure... and i can't seem to figure out which fuse is responsible for moving the seat forward/back. The seat is currently jammed as far forward as it can go, so i literally can't even fit in it to drive. Otherwise i would have gone to the nearest Autozone/Shop to ask for some help. If someone could be kind enough to give me insight on what the fuse panel and fuse rating is. Any help would be highly appreciated. Thanks in advanced! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2018 Share Posted August 6, 2018 http://people.csail.mit.edu/ilh/vacation/ the service manual may help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bigBADbenny Posted August 7, 2018 Share Posted August 7, 2018 The first step I’d take would be to identify which motor controls the fore/aft movement (eg from a spare drivers seat or google image search) and tap the affected motor housing body with a small heavy object, probably accessing it from the rear drivers side footwell. Remove the two rear mount bolts for better access if required. It may be the brushes are stuck in the housing. Once the seat can be moved to the mid point, remove it for further inspection/motor service or replacement. The loom should be continuity checked as well, iirc adm cars that are equipped with seat position memory have a lockout connected to the park brake, so that is a possible consideration. I’d put my money on a worn motor or a jam in the track... Link to comment Share on other sites More sharing options...
johnyaya Posted August 11, 2018 Share Posted August 11, 2018 My 07 Legacy had seat motion problems too, but it was the switch. I removed the seat from the car, removed and disassembled the switch, and cleaned/burnished the contacts. Now it works. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 12, 2018 Share Posted August 12, 2018 Coin or something stuck in the track Link to comment Share on other sites More sharing options...
