Volta55 Posted September 27, 2017 Share Posted September 27, 2017 Hi all, I'm a bit stumped trying to find a vacuum leak and maybe someone has an idea cause I'm out of 'em. When driving and boosting, my A/F Learning is fine... +/- 5% Once I tap on the brake, my A/F #1 shoots to the max 14.99% and stays there until I accelerate, and returns to a good A/F. What do you guys think? Any way to test the check valve? -oem panel filter- -sprayed MAF/ IAT -installed new oem turbo inlet 2 months ago Link to comment Share on other sites More sharing options...
MilesA Posted September 27, 2017 Share Posted September 27, 2017 Did you re-route any vacuum lines associated with the brake booster or fuel pressure regulator? Link to comment Share on other sites More sharing options...
Volta55 Posted September 27, 2017 Author Share Posted September 27, 2017 No When installing the new OEM turbo inlet, I took everything apart, installed, then reversed the steps; no mix up. The A/F #1 14.99% learn was like this even with the old slightly torn inlet installed Link to comment Share on other sites More sharing options...
relative4 Posted September 27, 2017 Share Posted September 27, 2017 Just to verify, you're fine at idle, right? This only happens when you tap the brake? If so, you have a leak in the brake booster or its check valve. Diagnostic procedures for brake booster leaks are pretty standard across most cars, you can google that or look it up in the vacation pics. Link to comment Share on other sites More sharing options...
Volta55 Posted September 27, 2017 Author Share Posted September 27, 2017 in Park (5EAT) with no foot on the pedals, she idles fine. in Drive, waiting at a red light ( foot on brake ) its rough. Will check out Vaca pics... thanks Link to comment Share on other sites More sharing options...
relative4 Posted September 28, 2017 Share Posted September 28, 2017 And in Park when you depress the brake - lean and rough, correct? Link to comment Share on other sites More sharing options...
gimpydingo Posted September 28, 2017 Share Posted September 28, 2017 Make a boost tester or go to shop and get it smoked. Can you load up a LV for us? Link to comment Share on other sites More sharing options...
Volta55 Posted September 29, 2017 Author Share Posted September 29, 2017 Just popped the hood, removed check valve from booster and hose, and it is functioning properly. booster hose does not look cracked And in Park when you depress the brake - lean and rough, correct? Im not totally sure about that.. Ill test it during my lunch break Make a boost tester or go to shop and get it smoked. Can you load up a LV for us? Yeah I will post an LV shortly.. I've also been fighting with an exhaust manifold to up-pipe gasket connection. Bought a grimspeed thick gasket, IAM was holding 1.000 for about 100 miles and yesterday it dropped to 0.875, so A/F #2 % is starting to creep up. but A/F #1 has been 14.99% always (since i got BTSSM hooked up.. about half a year ago ) Link to comment Share on other sites More sharing options...
