08spec.b. Posted September 4, 2017 Share Posted September 4, 2017 Hello, I was driving home from work today and noticed almost a lag while accelerating. I parked it and then started it back up and it started to stall out just barely stayed at idle and then jumped back up to 1,000 RPM. It also had the traction control light show up? It will throw the VDC when it's about to stall out No CEL yet. Now when I come to a stop it's a 50/50 chance it's stutters out and almost dies. Any ideas? I also checked the oil yesterday and noticed it was a little low so I added some. Then thought it was too much (just barely over the F on the dipstick) so I drained some out. -thanks! Tony Link to comment Share on other sites More sharing options...
ehsnils Posted September 4, 2017 Share Posted September 4, 2017 Manual or automatic gearbox? Some automatic gearboxes have issues with a binding torque converter, but I think it's primarily a CVT issue. Otherwise I'd check for air leaks in the intake manifold, bad PCV valve, shrunken donut gaskets and similar. And as usual - clean MAF and have a fresh air filter. You may need to do a reset of the ECU after a cleaned MAF. Disconnect battery, push brake pedal 20 seconds, reconnect battery. Notice that you will have to drive the car a few times cycling from cold to warm to let it re-learn after that. The need for re-learning also exists after you have had the battery disconnected for other reasons. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 4, 2017 Author Share Posted September 4, 2017 It's a 6MT gearbox. So would refrain from driving it until all that it done? Link to comment Share on other sites More sharing options...
Infosecdad Posted September 4, 2017 Share Posted September 4, 2017 Look for vacuum leaks, the blue tee under the intercooler is notorious for coming off the intake when the hose gets old and stiff. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 4, 2017 Author Share Posted September 4, 2017 I'll check that! I also forgot to add it feels like it's building boost at higher RPM. Almost like not much at 2-3k rpm bout 4krpm is where it starts to really pull. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 4, 2017 Author Share Posted September 4, 2017 Look for vacuum leaks, the blue tee under the intercooler is notorious for coming off the intake when the hose gets old and stiff. I can't find the blue tee connector I removed the TMIC just kinda stuck now Link to comment Share on other sites More sharing options...
Infosecdad Posted September 4, 2017 Share Posted September 4, 2017 http://legacygt.com/forums/showthread.php/intake-vacuum-leaks-and-you-pics-inside-235626.html Picture #7 on this thread. You can only see the center piece of blue, but one of the arms goes straight toward the front of the car and connects to the back of the intake. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 4, 2017 Author Share Posted September 4, 2017 Thanks for the info everyone! So I took off the TMIC and checked the hoses everything seemed pretty good? I do recall one of the screws to the TMIC being a little bit loose. I took it on a drive it's a little better. What should the idle RPM be sitting at? It's idling between 600-800 Link to comment Share on other sites More sharing options...
sshole Posted September 4, 2017 Share Posted September 4, 2017 I get the feeling that this "blue tee under the intercooler" is only a thing for 05-07 LGT owners, not for 08+ LGT owners. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 5, 2017 Author Share Posted September 5, 2017 I get the feeling that this "blue tee under the intercooler" is only a thing for 05-07 LGT owners, not for 08+ LGT owners. I agree. I couldn't find it for the life of me. Felt an idiot and just threw it all back together. Link to comment Share on other sites More sharing options...
Darth SpecB Posted September 5, 2017 Share Posted September 5, 2017 I have an 09 with the tee. I'm sure it's there. But if you don't have anymore driveability issues you probably found the boost leak. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
08spec.b. Posted September 5, 2017 Author Share Posted September 5, 2017 So I went and got a new air filter and man was the old one dirty!!!! It's not stalling anymore! Only thing I am having a slight issue with is it's not building boost at lower RPM you can really feel it hit around 4K rpm. What's normal boost peak for these? And what's normal idle? Link to comment Share on other sites More sharing options...
gimpydingo Posted September 5, 2017 Share Posted September 5, 2017 07+ should not have the blue T. Boost peak is around 3500, with boost starting to build around 2500. With a manual you should be taking off smoothly. You should pressurize or smoke test your system. Seems like a vac leak. Link to comment Share on other sites More sharing options...
ehsnils Posted September 5, 2017 Share Posted September 5, 2017 It's a 6MT gearbox. So would refrain from driving it until all that it done? If it's a 6MT then it's not a problem there at least. Link to comment Share on other sites More sharing options...
