Rudeboy47 Posted May 16, 2014 Share Posted May 16, 2014 And I'm cooking in my legacy!! Before I did my timing belt my a/c worked great. After I did the timing belt the a/c stopped working. The light on the ac button doesn't come on when the button is pressed. What could this be? It should be something simple rite? Where can I start looking? Link to comment Share on other sites More sharing options...
DGR81 Posted May 16, 2014 Share Posted May 16, 2014 Did you add the Freon? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 16, 2014 Share Posted May 16, 2014 I know this is not entirely related, but it is: If you don't have tinted windows, get them. They will do as much to help control the temps in your car as the A/C will. Link to comment Share on other sites More sharing options...
WhoUtink Posted May 16, 2014 Share Posted May 16, 2014 Put the belt back on. I keed. Link to comment Share on other sites More sharing options...
Bandit240 Posted May 16, 2014 Share Posted May 16, 2014 Check the wire going to the compressor clutch. It may have been knocked off when you did the timing belt. You didn't happen to remove the lines to the compressor? If so, you need to take it to a shop to be refilled. Link to comment Share on other sites More sharing options...
boattlebot Posted May 16, 2014 Share Posted May 16, 2014 Yea it sucks having no ac, this is my 4th car that it dont work. Monday tho the climate control class at my school should be able to get my car in and tell me whats wrong with it. Id look myself but I dont got the guages to see if its a low charge, all I can do is see if my compressior works witch Im 99% sure it dose. Post whoring/bitching is now compleate Link to comment Share on other sites More sharing options...
Rudeboy47 Posted May 16, 2014 Author Share Posted May 16, 2014 The clutch on the compressor does not engage and I check the wiring and everything seems fine Link to comment Share on other sites More sharing options...
Bandit240 Posted May 16, 2014 Share Posted May 16, 2014 Check the fuse for it. If the fuse is good, pull the wire loose while the switch inside is on and check to see if there is voltage at the wire. Link to comment Share on other sites More sharing options...
Rudeboy47 Posted May 16, 2014 Author Share Posted May 16, 2014 Check the fuse for it. If the fuse is good, pull the wire loose while the switch inside is on and check to see if there is voltage at the wire. Where's the fuse for it? I only found the relays Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 20, 2014 Share Posted May 20, 2014 Should be under the kick panel on the driver's side. Link to comment Share on other sites More sharing options...
ssbtech Posted May 20, 2014 Share Posted May 20, 2014 Might also want to check the relay. I had to replace the relay in my '05. Not that the A/C is of much good in these cars anyway. Link to comment Share on other sites More sharing options...
