Lewegee Posted December 18, 2018 Share Posted December 18, 2018 Rack went in smoothly on my 06 OBXT limited; steering heavier at low speeds (wife displeased) and very tight/true at high speed. No dead zone on center, very quick responses to inputs. No VDC on ‘06 so not an issue though others report problems. Mechanic (The Shop in Norwalk, CT) said went in easy, ~3/4” thread left available on tie rods (more than expected, possibly due to 1.5” drop on coilovers?) All in all very pleased since old rack was weeping like crazy and this was same price as oroginal OEM. Link to comment Share on other sites More sharing options...
tominator19 Posted January 14, 2019 Share Posted January 14, 2019 What's going on with this guy? He's talking about using modifications to the CAN signals to adjust for steering rack differences to keep VDC after an STI steering rack swap. "STEERING SENSOR CAN-ID 0X2 ... This info has been successfully used for steering rack swap, i.e. mating STI part with standard model. By translating this CAN frame data, a different steering ratio can be used with properly functioning VDC." https://subdiesel.wordpress.com/ecu-analysis/can-messages/ Link to comment Share on other sites More sharing options...
bigBADbenny Posted January 21, 2019 Share Posted January 21, 2019 (edited) ^ used an arduino with 2 can shields to intercept the can signal for steering wheel angle, apply a correction factor as the can output to vdc. One of these posts: https://www.google.com.au/search?client=safari&hl=en-gb&ei=AbpFXO3TC8H6rQHP6ouQCA&q=site%3A+legacygt.com%2Fforums+arduino+&oq=site%3A+legacygt.com%2Fforums+arduino+&gs_l=mobile-gws-wiz-serp.3...2086.5797..7482...0.0..0.472.2583.2-8j0j1......0....1.........0i71j35i39j0i22i30j33i160j33i21.N2TB6sLItJM Specifically: https://legacygt.com/forums/showpost.php?p=5373883&postcount=193 Absolute genius but last time I searched little extra detail was available Picking up the trail of breadcrumbs : https://forums.nasioc.com/forums/showpost.php?p=45331980&postcount=79 Ozfoz: http://ozfoz.com/forum/viewtopic.php?f=29&t=56658&start=0&st=0&sk=t&sd=a GitHub: https://github.com/Phrewfuf/sas-scaler Edited January 22, 2019 by bigBADbenny Link to comment Share on other sites More sharing options...
captainobvious Posted February 10, 2020 Share Posted February 10, 2020 Just installed my 2015 STI rack in my LGT. Much easier when the motor is completely out of the car. Did everything but the knuckle. Have to say the responsiveness and control is awesome. Kudos for the upgrade. Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 18, 2020 Share Posted February 18, 2020 I read a post somewhere mentioning that no trimming of the inner tie rod ends (but use a thinner jam nut) is required when using the Whiteline RCA kit tie rods, in narrow body cars. Link to comment Share on other sites More sharing options...
Code Posted May 1, 2020 Share Posted May 1, 2020 Does the LGT/Whiteline steering rack bushing kit fit the STI rack? Underdog, do you still supply these racks? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Underdog Posted May 1, 2020 Author Share Posted May 1, 2020 Does the LGT/Whiteline steering rack bushing kit fit the STI rack? Underdog, do you still supply these racks? Yup the Whiteline steering rack bushing kit does fit. More details in the “what other parts are needed?” section of the OP. Unfortunately no. I’ve been out of the parts business for a few years now. The Crimson Dynamo Link to comment Share on other sites More sharing options...
SpecDubC Posted July 15, 2020 Share Posted July 15, 2020 Doing this mod next weekend on my 08 spec b. I have the whiteline rod ends already and tried to find those jam nuts locally but wasn't convenient from the metric supply places so looks like I'm buying the 5 pack from McMaster so I don't have to cut the ends. Doing U-Joint also, one of like 3 left in the US apparently. Gotta think they make small runs of these rarer parts when they run out. Also the Cusco brace. Did you also replace your hanger bracket and paint it? Sent from my Pixel 3 using Tapatalk Link to comment Share on other sites More sharing options...
Underdog Posted July 19, 2020 Author Share Posted July 19, 2020 Yeah the rack came with a new one and I had them all powder coated. Good luck with the install! The Crimson Dynamo Link to comment Share on other sites More sharing options...
xrayspecs Posted July 24, 2020 Share Posted July 24, 2020 Underdog, thanks for the solid walk through and information with part numbers on your installation of the STI rack. It helped a bunch for my install on a 3rd gen. Link to comment Share on other sites More sharing options...
rhino6303 Posted July 28, 2020 Share Posted July 28, 2020 Has anyone else read that you can use outer tie rods from an '88 GL for this swap as they are shorter? Downside is that they are the curved type. Here is a link for where it was done. https://www.blingstrom.com/diy-project/2020/5/4/15-sti-steering-rack-install-on-a-2005-sti-how-to-fit-the-quicker-rack-in-your-older-subaru Link to comment Share on other sites More sharing options...
bigBADbenny Posted August 5, 2020 Share Posted August 5, 2020 That diy is next level! Or use Whiteline RCA kit tie rod ends with thinner or shaved jam nuts. Link to comment Share on other sites More sharing options...
portisroads Posted September 2, 2020 Share Posted September 2, 2020 So are we all in agreement that 34110VA131 will work just the same as 121? There is a wrecked sti with 5k selling it's steering rack locally. Link to comment Share on other sites More sharing options...
Rhitter Posted September 3, 2020 Share Posted September 3, 2020 Has anyone else read that you can use outer tie rods from an '88 GL for this swap as they are shorter? Downside is that they are the curved type. Here is a link for where it was done. https://www.blingstrom.com/diy-project/2020/5/4/15-sti-steering-rack-install-on-a-2005-sti-how-to-fit-the-quicker-rack-in-your-older-subaru I don't know why you would do that. The modifications in this thread (i.e. cut them) are super easy and free. My OBXT build Link to comment Share on other sites More sharing options...
rhino6303 Posted September 3, 2020 Share Posted September 3, 2020 I don't know why you would do that. The modifications in this thread (i.e. cut them) are super easy and free.Not saying I would or will. I was just curious if anyone here has because some didn't want to cut their tie rods. This would give them the same adjustability without cutting the tie rods. Personally, I would cut the tie rods so I could use oem tie rod ends rather than aftermarket. Link to comment Share on other sites More sharing options...
captainobvious Posted September 5, 2020 Share Posted September 5, 2020 i did not have to cut the tie rod ends. I was able to get the car aligned perfectly. i used my 2005 LGT end Links on the 2015 inner tie rods and no cutting was necessary. Link to comment Share on other sites More sharing options...
SpecDubC Posted September 8, 2020 Share Posted September 8, 2020 i did not have to cut the tie rod ends. I was able to get the car aligned perfectly. i used my 2005 LGT end Links on the 2015 inner tie rods and no cutting was necessary. When I put the new rack with my whiteline ends the other day i just matched the distance 7-7/8" from the end of the rubber boot to the start of the end (minus nut). This matched to what distance I had on the old rack and I ended up using the smaller jam nuts just because otherwise I would've only had about 3 rows of threads left to the inside and I already had purchased them so this gave some more adjustability if needed in the future. Now I just have two sti tie rod ends to sell along with a leaky steering rack haha. Link to comment Share on other sites More sharing options...
HellShadow70 Posted October 30, 2020 Share Posted October 30, 2020 i need to do this asap Link to comment Share on other sites More sharing options...
SpecDubC Posted November 6, 2020 Share Posted November 6, 2020 When I put the new rack with my whiteline ends the other day i just matched the distance 7-7/8" from the end of the rubber boot to the start of the end (minus nut). This matched to what distance I had on the old rack and I ended up using the smaller jam nuts just because otherwise I would've only had about 3 rows of threads left to the inside and I already had purchased them so this gave some more adjustability if needed in the future. Now I just have two sti tie rod ends to sell along with a leaky steering rack haha.This ended up me not having center on the rack somehow but it's aligned now aside from being pretty much bottomed out on one tie rod end of the threads. I can probably get it close to center next time if I just turn the wheel to the other side some, undo the u joint, then turn it back and reconnect while adjusting the tie rod ends an even amount. Next time I need an alignment for other reasons I'll do this. Also just rebuilt my pump with new seals/orings successfully, but that's another thread. Other than that the upgrade went great and the car as been driving equally as good. With the upgraded u joint I definitely feel more in control with the finite response to the steering! Sent from my Pixel 3 using Tapatalk Link to comment Share on other sites More sharing options...
DwntwnDanny Posted April 11, 2021 Share Posted April 11, 2021 Quick question, you guys still sell these racks? Might be interested in picking one up soon. Also located in Mass. Sent from my IN2017 using Tapatalk Link to comment Share on other sites More sharing options...
Kaos22B Posted April 12, 2021 Share Posted April 12, 2021 I just finished this install but on a swapped GC, which was a bit more work. New crossmember, new column, custom adaptor for column to rack, modified thread adaptors to use factory ITRs, factory 15+ lines and pump. Waiting on a driveshaft and finishing up some other driveline parts to drive it and compare it to my swapped RS that has a GD STi 15:1 rack, to see if all that work was worth it. I'm thinking on a super light and small GC, it may be too quick for a street car. It will be nice to compare and give an idea of what the Spec B would be like with it however, and the install on that should be easier. Link to comment Share on other sites More sharing options...
seanyb505 Posted May 8, 2021 Share Posted May 8, 2021 I've got a brand new sti rack and associated bushings. Should I: 1. Leave bushings stock 2. Replace with whiteline ksr207 3. Replace with energy suspension 12344.58697.123 or whatever their pn is Link to comment Share on other sites More sharing options...
captainobvious Posted May 9, 2021 Share Posted May 9, 2021 go with the Whiteline bushings as well as the perrin steering dampener. World of difference in steering and really tightens everything up. Link to comment Share on other sites More sharing options...
seanyb505 Posted May 13, 2021 Share Posted May 13, 2021 My plan includes the sti solid linkage rather than the perrin piece. Finally ordered. Didn't want to wonder once it was all put back together. Link to comment Share on other sites More sharing options...
