kj4dow Posted June 15, 2019 Share Posted June 15, 2019 I decided to install fog lights on my 2015 Subaru Legacy. The instll of the ights was pretty straight forward, found the exisitng wires exacltly where the instructions said they were. When I got inside the car, I pulled the switch pannel off to instal the push button switch, no wire harness was preaent. In doing some research, some kits for the same car, came with a new turn signal knob, that has the switch. Has anyone run into this and can guide me on my next course of action? Thanks. Link to comment Share on other sites More sharing options...
ammcinnis Posted June 15, 2019 Share Posted June 15, 2019 Keep looking. It's there behind the switch panel. (I assume your 2015 is Base trim.) "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Zarmien Posted June 16, 2019 Share Posted June 16, 2019 the plug for the switch goes into one of the preexisting switches next to it. Link to comment Share on other sites More sharing options...
kj4dow Posted June 16, 2019 Author Share Posted June 16, 2019 Thanks for the quick reply. I looked again and I still dont see it. In you message you said the my trim level was base, I did a vin search and it indicated my trim level was 2.5i premium. Link to comment Share on other sites More sharing options...
Painless Posted June 16, 2019 Share Posted June 16, 2019 I ran into the same issue installing the OEM aftermarket fog lights. (I am assuming that this is what you are doing) There is another connector that gets plugged into the fog light switch. It is part of the Trunk unlock & Dimmer connector bundle. Black/Yellow-Green-Black/white-White wires running into an unused connector. I took some pics and will throw-together a quick pdf for you. Hope this helps. Link to comment Share on other sites More sharing options...
Painless Posted June 16, 2019 Share Posted June 16, 2019 Here's the pdfAftermarket Fog Light Switch Install 2.pdf Link to comment Share on other sites More sharing options...
Painless Posted June 16, 2019 Share Posted June 16, 2019 Additional pics.Aftermarket Fog Light Switch Install 1.pdf Link to comment Share on other sites More sharing options...
PATS4LIFE Posted June 17, 2019 Share Posted June 17, 2019 If you have the premium model then your fog light switch should be on the stalk with headlight/turn switch,well at least that’s where mine is. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ammcinnis Posted June 17, 2019 Share Posted June 17, 2019 In you message you said the my trim level was base, I did a vin search and it indicated my trim level was 2.5i premium.Premium without EyeSight should be the same wiring as Base trim. Did you not receive installation instructions with your kit? See: https://techinfo.subaru.com/stis/doc/accInstallGuide/077217-H451SAL000IxILegacyFogLightKit.pdf "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
OmahaLegacy01 Posted June 28, 2019 Share Posted June 28, 2019 If you look next to the dashboard dimmer dial, you’ll see there is a wiring harness going into the blank switch, that’s the harness for your fog lights, I just did this install on Tuesday, it took me forever to find it since it wasn’t stated clearly in the instructions Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
