ChrisC92 Posted August 7, 2012 Share Posted August 7, 2012 Hello, I have just installed some new Cometic MLS head gaskets on my subaru legacy EJ20 engine. everything works great except when I release the throttle, the rpm far under the normal idle point(it nearly dies) and then it stabilizes itself. Also the "Check Engine" light up randomly. what could be wrong? I have been searching for solutions and this is what the problem could be according to other people: -Valves need to be adjusted -ECU needs to be reset and relearned(disconnect battery for X minutes and drive) -Too much air in the intake Here is some photos of valves etc: https://www.dropbox.com/sh/ky1i3agcp9pdyft/R-DAUjofFT Link to comment Share on other sites More sharing options...
Stasis Posted August 7, 2012 Share Posted August 7, 2012 Pull the code Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted August 7, 2012 Share Posted August 7, 2012 Check your MAP/MAP sensor & the plug that goes into it. Also double check the whole intake to make sure you closed everything up. Even the slightest bit of extra unmetered air will cause a stall at idle. Link to comment Share on other sites More sharing options...
ChrisC92 Posted August 10, 2012 Author Share Posted August 10, 2012 I found one opening on the intake that was leting in some air, i fixed the gap and it helped a little. Here is the trouble code that i pulled out: http://dl.dropbox.com/u/3375306/VIDEO0015.mp4 (Air control valve inoperative (Abnormal signal produced in monitor circuit)?) Link to comment Share on other sites More sharing options...
