blackobxt Posted August 14, 2020 Share Posted August 14, 2020 I used to clean mine regularly, till I moved to the desert....... Link to comment Share on other sites More sharing options...
Nonamedude Posted August 14, 2020 Author Share Posted August 14, 2020 *twitch* year without cleaning interior, I'd lose my mind. My inner monologue gets abusive after a week I used to clean mine regularly, till I moved to the desert....... Basically this. There is a dust layer on the car within a few hours of washing it even if you're very anal about drying everything. Main issue has been lack of space to work and any time I had a moment I had to do mechanical repairs. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 14, 2020 Share Posted August 14, 2020 I'm not sure what you mean by radiator end cap seals. The plastic tanks on the radiator itself? Nah this is the first I've actually seen or smelled coolant. Now my car wreaks of coolant lol. Sent from my iPhone using Tapatalk Yeah my first one was leaking between the aluminum and plastic. At some point they just fail. Sorry your still smelling coolant. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 14, 2020 Share Posted August 14, 2020 ^ That's true. I have two OBXTs and they both failed last year at the top seam. Both OEM. Link to comment Share on other sites More sharing options...
Nonamedude Posted August 14, 2020 Author Share Posted August 14, 2020 Yea once things are stable I'll probably use it as an excuse to get a nice radiator. I'm pretty sure it's about 40-45k miles and it's some weird brand. I tried looking it up but I think maybe it's an oem manufacturer label. Or its a cheap knock off radiator lol. Maybe I'll make bank in Michigan doing door dash and can get some blingy aluminum radiator. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted August 17, 2020 Author Share Posted August 17, 2020 What a weekend. We ended up having unrestricted media access which meant that, after some off roading where I almost lost my bumper in a dip I thought I could make and a good workout on my skid plate, we stuck to just driving the stages. Got to drive 5 of the 6 which was pretty cool and the extra height and awd both came in handy. Didn't have any issues with oil or coolant over the drive which was great. But towards the end I got a check engine. P2096 post cat fuel trim lean. I've checked my learning view and it looks good and I'm not showing any knock. Looks like I'll be pulling my downpipe to take to the muffler shop. No way I'm trying to take out that sensor. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted August 17, 2020 Share Posted August 17, 2020 Am I mistaken or can that after cat O2 sensor be deleted in the tune map ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 17, 2020 Share Posted August 17, 2020 ^^ Yes. You'll know right away whether it was done correctly or not. If it's not done right, the fueling target compensation for the aft O2 will still be active and, due to not having the sensor, your car will be targeting an idle/cruise AFR of 13.6-13.8 instead of 14.7. Link to comment Share on other sites More sharing options...
Nonamedude Posted August 17, 2020 Author Share Posted August 17, 2020 Oh interesting. I thought it was a mechanical fix. At least that seems to be the case on NASIOC for the WRX running a catless dp. I'd love to save a few bucks for now, I spent it all at the rally. I'll have to look that up since it's apparently not just turn off the CEL. And you were right about the dust. It's everywhere. Even places it shouldn't be. Like I figured there'd be some but I was not prepared. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 17, 2020 Share Posted August 17, 2020 (edited) The dust. Yes there's a big difference from working the Mt Washington Hill climb to the New England Forrest Rally. Some sections of the Forrest Rally are pretty dusty, others are deep in the woods. Mosquitoes become the issue then... Mt Washington June 2014, Travis, left us a gift ATTACH]286406[/ATTACH] Another spot we were stationed at. Not sure what happened there, but that last picture is what Travis left us. Edited August 17, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nonamedude Posted August 17, 2020 Author Share Posted August 17, 2020 Oof mosquitoes. I've forgotten about them. I'm going to try to make it to Lake superior performance rally so I'll try to remember about that. My favorite problems are ones that fix themselves. After checking all the stuff, I drove home with that CEL, 200ish miles. Well I just got into the car to head to a Dr appointment and no more CEL. I'll check my fuel trims again when I get home this evening and I'll be putting in a new air filter as well. Probably keep this one and try to blow it out when I get a chance. Everything still feels and sounds fine so here's to hoping things were just overly dusty or overly jostled. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted August 17, 2020 Author Share Posted August 17, 2020 We didn't have any injuries luckily but we had a fiesta roll over a drop and the media director had an off during recce that took out the fender and mirror of his rental. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jaylew Posted August 17, 2020 Share Posted August 17, 2020 ^^ Yes. You'll know right away whether it was done correctly or not. If it's not done right, the fueling target compensation for the aft O2 will still be active and, due to not having the sensor, your car will be targeting an idle/cruise AFR of 13.6-13.8 instead of 14.7. What do you mean done correctly? I just reflashed the ECU but with all codes concerning the rear O2 sensor turned off. Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
rhino6303 Posted August 17, 2020 Share Posted August 17, 2020 What do you mean done correctly? I just reflashed the ECU but with all codes concerning the rear O2 sensor turned off.You have to add tables specific to either ecuflash or romraider to disable the rear o2 fueling corrections (you zero them out). Just clearing the rear o2 sensor codes doesn't disable the sensor from affecting fuel trims. See this thread on romraider for more information. https://www.romraider.com/forum/viewtopic.php?f=40&t=8131 Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 17, 2020 Share Posted August 17, 2020 What he said. Are these tables already defined for the AP folks? Never thought to find out. Link to comment Share on other sites More sharing options...
Nonamedude Posted August 17, 2020 Author Share Posted August 17, 2020 OK that makes way more sense. I thought that rear one was the one that handled fueling corrections. In which case, I'd be correct in thinking that if it was acting up, I'd see bad fueling corrections? Might disable it before my move though either way. Just so I don't have a panic attack while towing Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 17, 2020 Share Posted August 17, 2020 Actually they both do. The rear one is there to impose corrections based on measured catalytic converter performance, if I recall correctly. Link to comment Share on other sites More sharing options...
jaylew Posted August 17, 2020 Share Posted August 17, 2020 Thanks for the info! I am quite novice with use of romraider...I bought it to eventually tune but it has primarily served its purpose of helping me pass annual inspections. Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
Nonamedude Posted August 23, 2020 Author Share Posted August 23, 2020 Got under the car today to do a number of things. One was to inspect the wiring and connection of the rear o2 sensor. Doesn't look to be damaged or loose after my off road adventures. The CEL will go off on its own after 50-100 miles but then come back. I put the new air filter in and it's off right now. Fuel trims still look fine. If it comes on again I'll just zero out that sensor and be done with it for now. I just hate to mess with Dave's tune. Also found the rear bolt on the skid plate, which goes into the engine crossmember was pretty loose. This was causing a rattle when the cooling fans when spin up. Makes sense due to the front bolts being in the front crossmember. It was crazy trying to figure out why the fans would come on and I'd hear a rattle in the back of the bay. Hopefully the clears up my false knock. No major issues post rally other than losing my tow hook cover and my front bumper fitment isn't great now. But not terrible. Looks like I got a small dent on a frame rail from a rock but that's all. Also put my kartboy end links on the front. Easy. But didn't solve my low speed clunk. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted August 31, 2020 Author Share Posted August 31, 2020 You have to add tables specific to either ecuflash or romraider to disable the rear o2 fueling corrections (you zero them out). Just clearing the rear o2 sensor codes doesn't disable the sensor from affecting fuel trims. See this thread on romraider for more information. https://www.romraider.com/forum/viewtopic.php?f=40&t=8131 Holy jeez. Tried looking this up tonight and it's way over my head. I'll have to look again when I haven't spent the entire day packing stuff. It's not a defined table in my rom. Link to comment Share on other sites More sharing options...
Nonamedude Posted September 17, 2020 Author Share Posted September 17, 2020 Well it made it. Got to Michigan late last night. It was tough. Lots of driving with an unfortunate detour to Denver. Saw some temp climbing a few times on steep hills and had to do like 30mph up the canyon leaving utah but we made it without issue. Trailer is still loaded. I'd like to go weigh everything to get an idea of what I was actually pulling. Empty weight is 1900 and like 200 tongue weight. Definitely had a lot of weight, too much likely, on the hitch. Going from slc to Cheyenne it used nearly a quart of oil. But I also basically drove at 4k rpm and 70% throttle the whole way. Basically after Wyoming it was smooth sailing. No knock, no noises, no oil or coolant usage. I wouldn't suggest it get done regularly, but I made it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
blackobxt Posted September 17, 2020 Share Posted September 17, 2020 Wait did you move to Cheyenne? That’s a lot of trailer on that car lol Link to comment Share on other sites More sharing options...
Infosecdad Posted September 17, 2020 Share Posted September 17, 2020 He moved from Utah to Michigan. That is a lot of trailer for that poor OBXT, almost surprised that U-Haul let you do that. That's the only U-Haul trailer I hadn't used yet on my LGT Link to comment Share on other sites More sharing options...
blackobxt Posted September 17, 2020 Share Posted September 17, 2020 Ahhhh. Yeah when he was talking about pulling a trailer I thought it was one of the smaller ones. How’d she do at speed? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 17, 2020 Share Posted September 17, 2020 I bet the car had enough power to pull this. Problem is cooling and gas mileage. How high did your coolant temp go? And now you can enjoy 93 octane. A slight but noticeable small bump in torque provided you get a tune for it. Link to comment Share on other sites More sharing options...
