amm203 Posted November 1, 2016 Share Posted November 1, 2016 Just dropped my Subaru off at the dealer for a tranny fluid change and was informed there is a recall on our cars for the turbo air pump. Here's what I've found so far about it... http://abcnews.go.com/Business/wireStory/subaru-recalls-models-turbo-air-pump-catch-fire-43068127 Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2016 Share Posted November 1, 2016 I guess that info hasn't made it to the east coast yet. I happened to mention it to the Service attendant when I picked up my wagon today. He said he knows there's a airbag recall, but nothing about a air pump... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
solidxsnake Posted November 1, 2016 Share Posted November 1, 2016 Yeah, someone else posted about it recently. From my cursory glance it is caused by a faulty relay. If so, it shouldn't take nearly as long as the airbag recall (which I still haven't bothered to schedule). Link to comment Share on other sites More sharing options...
firepyro515 Posted November 1, 2016 Share Posted November 1, 2016 I am curious as to which LGTs are impacted Link to comment Share on other sites More sharing options...
amm203 Posted November 2, 2016 Author Share Posted November 2, 2016 The service guy was surprised by it as well. It is *some 07-09 Legacies, 08-14 Imprezas and 09-13 Foresters. Is it likely that the VIN determines it showing up as a recall? With only 2 documented cases and 100,000 recalls it appears to be a small sample. Regardless, like solidxsnake says, it is a simple fix! Link to comment Share on other sites More sharing options...
RJ255 Posted November 2, 2016 Share Posted November 2, 2016 I actually saw this on the local news on Friday. All the more reason for the those who have the D25 heads w/the air pump to just delete it. Not expensive ( I had to do it on my D25 heads that replaced B25s) Link to comment Share on other sites More sharing options...
67firebirdak Posted November 2, 2016 Share Posted November 2, 2016 Interesting to know, thanks for the tip. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted November 2, 2016 Share Posted November 2, 2016 I'd rather my let my car catch fire with me in it than go to the Dealership for service. Link to comment Share on other sites More sharing options...
Code Posted November 2, 2016 Share Posted November 2, 2016 Can you remove the air pump system with the motor still in the car? If so, I may do it. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
amm203 Posted November 2, 2016 Author Share Posted November 2, 2016 Can you remove the air pump system with the motor still in the car? If so, I may do it. I would think so. Subaru dealer had the car back to me within 24 hours and that was with other services being done. *ah nevermind - re-read your post. I know the relay is all they replaced. Can't comment on removing the whole system without removing the engine. Link to comment Share on other sites More sharing options...
amm203 Posted November 2, 2016 Author Share Posted November 2, 2016 I'd rather my let my car catch fire with me in it than go to the Dealership for service. Haha normally I'd agree with you but I've found not all Subie dealers are equal. There are two near me separated by 30 miles and they are vastly different in terms of quality/personnel and prices. A full 12Q tranny flush at one is 200$ while it is 145$ at the other. There are some things I'd rather just have the dealer do as well - like change out ball joints and tie rods for the WL RCA kit, especially since it needs an alignment afterwards anyways. However, charging 39$ for a 5EAT TCU update is horseshit. It did make the shifting much more smooth, though. Link to comment Share on other sites More sharing options...
Code Posted November 2, 2016 Share Posted November 2, 2016 I would think so. Subaru dealer had the car back to me within 24 hours and that was with other services being done. I think that they just replace a relay for this recall. I want to delete the entire system. I'm stage 3 and I don't see any reason for the dealer to touch my car, but I also don't want the car to burn to the ground. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
RJ255 Posted November 3, 2016 Share Posted November 3, 2016 I think that they just replace a relay for this recall. I want to delete the entire system. I'm stage 3 and I don't see any reason for the dealer to touch my car, but I also don't want the car to burn to the ground. Check out m sprank's post on the air pump delete: http://legacygt.com/forums/showthread.php/2007-2009-air-pump-delete-cel-codes-and-ecu-fix-140259.html Link to comment Share on other sites More sharing options...
