the yellow top is their deep cycle battery - the red top is the more typical SLI battery. Folks seem to indicate that the quality of Optima batteries has fallen off a bit. I'm running a Bosch AGM battery. Deka is also a good brand for AGM batteries.
  • 1 year later...
The best battery I have ever had was a GS Yuasa power series ultra, it has lasted 12 years and in fact was still working fine when I swapped it, its now my emergency jumper battery and its still working.
In part it comes down to the weight of the battery, the lighter it is the worse the performance/life.
Worst battery I had lasted 18 months, it was a AA emergency roadside fit when when failed in my girlfriends car. Pulled it out of the car and I thought this thing doesn't have any lead in it.
Dunno if you have a Napa near you, but their AGM batteries are (or were, at least) made by Deka. I bought the group 34 75-month Napa Legend (Napa p/n 9834), which appears to be a rebadged Deka Intimidator (Deka p/n 9A34). No problems with it over the last 2-ish years. You might be able to get a better deal elsewhere, but the coupon I had (and the fact that I only had the one car at the time) made it worth the local purchase.
Yeah, there is a Napa just down the road a mile. I had a Deka Intimidator in the Forester and I liked it, especially go the price. I will look at the Napa Legend
Joe - did you ever get an Alt-S fuse mod on the LGT or only the Forester?
In general for others: Alt-S fuse mod + decent capacity AGM + battery kill switch (if garage queen or weekend warrior) + quarterly or semi-annual trickle charge to top off the battery, and the AGM should last 5-6 years easy.
Else, even with a good/great battery, the stock charging system and vampire drain from even the most basic accessories (let alone say an AP or Tactrix, OBD dongle, dashcam, etc.) will make short work of the state of charge and effective capacity of a new battery.
Yes, HBK Electronics MK3 is installed on the GT. Fault lies with the Exide AGM, which started having widespread failure issues around the time I purchased it for the GT. Had one die in the Fozz after only 2 months.
I’ve long been an Optima fanboy. But, last moth the 2.5 year old red top in my GT lost about half its CCA, still at 12v but car was cranking slow. Luckily Optima has a 3 year exchange warranty. Of note this battery was two years old (NOS) when I bought it, frustrating at the time but the only one the local Advance had in stock. Anyway, last month Advance exchanged the battery for a new one and restarted the 3 year warranty.
