Vaders_3.0R Posted September 25, 2013 Share Posted September 25, 2013 So I ordered a front plate bracket that I am going to mount on my lower grill to move my plate off to the tow hook side. (Not spending $80 for a Grimmspeed). Question is what do the auto body folks recommend filling the holes with? I am thinking just bondo and I have some OEM paint I can paint over it with. It doesn't need to be 100% but look clean and done well at the least. I will post a small DIY later this week once my bracket shows up. Link to comment Share on other sites More sharing options...
BrownBoy Posted September 26, 2013 Share Posted September 26, 2013 Another option is to sand the area around the license plate holes smooth and just find some vinyl that is really close to your paint color. I personally used S2000 bumper plugs to fill mine in. Link to comment Share on other sites More sharing options...
Vaders_3.0R Posted September 26, 2013 Author Share Posted September 26, 2013 I thought about that too. I bought a bumper hole repair kit from autozone for $10 should fill holes enough to be ok to sand and paint. Maybe I will try to plug and see how it looks first before going into bondo and all that. Link to comment Share on other sites More sharing options...
GTEASER Posted September 26, 2013 Share Posted September 26, 2013 For my Saturn years ago I just used flat plastic plugs I picked up at Home Depot, put a little of the OEM chip paint on them and it was good to go. Clean enough that I didn't really notice it and matched well enough that it actually looked good. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Vaders_3.0R Posted September 26, 2013 Author Share Posted September 26, 2013 ^+1 I might stop off by the hardware store and pick some up. I was thinking that and some decals to hide/keep them in place would do the trick. Really trying to avoid sanding and painted the holes if possible. Link to comment Share on other sites More sharing options...
Vaders_3.0R Posted September 26, 2013 Author Share Posted September 26, 2013 Plus I have a nice size Darth Vader decal that would sit nicely in that spot too lol. Link to comment Share on other sites More sharing options...
iNVAR Posted September 26, 2013 Share Posted September 26, 2013 Beware of sanding and painting if your paint is a metallic color. You're going to have a hell of a time blending. I'd personally go with bumper plugs of the same color and call it a day. Link to comment Share on other sites More sharing options...
Vaders_3.0R Posted September 26, 2013 Author Share Posted September 26, 2013 I have already had some rough times fixing some scuff on the back door handle. I ended up having to rub the paint in to blend it and then multiple sanding and touch up sessions. I think the plugs and some paint will do just fine. Who's gonna be up that close anyways right? Thanks all for the suggestions! I'll make sure to post up some pics when I get it all done. Beware of sanding and painting if your paint is a metallic color. You're going to have a hell of a time blending. I'd personally go with bumper plugs of the same color and call it a day. Link to comment Share on other sites More sharing options...
htioki Posted September 26, 2013 Share Posted September 26, 2013 Plastic plugs are what I used on mine. I went to Lowe's and picked up different types of plugs. At home, I tried them on to see which ones fit and look the best and returned the rest. I also sanded the surface of the plugs to roughen up the surface a bit so that the paint sticks better. It's been 3 years, and the plugs and paint still holding up fine. Some people went the extra mile and put some clear coat on them. Link to comment Share on other sites More sharing options...
IGW Posted September 29, 2013 Share Posted September 29, 2013 FUSOR or 3M make a 2 part epoxy for bumper repairs it is the only proprer way to fill the holes, but then sanding and painting will b nec. Link to comment Share on other sites More sharing options...
