richierozay Posted April 8, 2019 Share Posted April 8, 2019 I have looked but can't find 100% solid answer online but I'm trying to figure out the difference/feasibility of a N/A 5spd in a turbo car? Are all the manual transmissions interchangeable as long as you have a matching rear diff? Link to comment Share on other sites More sharing options...
Rhineholio Posted April 13, 2019 Share Posted April 13, 2019 I wish I knew more about this. Im sure it'll bolt right up but the gear ratios might be different between turbo and NA. As long as the final drive is the same as the rear end then you should be ok. Once again not a definite answer but hopefully someone else who knows more will chime in. Link to comment Share on other sites More sharing options...
richierozay Posted April 13, 2019 Author Share Posted April 13, 2019 After more research I was able to find out that the main difference between turbo n NA 5 speeds for 05 legacy is that NA has a push clutch and turbo has a pull clutch...same gear ratios and final drive...incase any1 else reading cares lol Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted April 16, 2019 Share Posted April 16, 2019 There is a different bearing set up in the GT's to handle more torque. You can see the difference if you study the opposedforces diagrams. I know because I have ordered enough of those parts for my wagon over the years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
