JDMBR9 Posted August 14, 2020 Share Posted August 14, 2020 hello does anyone know if the br9 shares the same brake master at the impreza wrx sti that has black brembos? reason i ask is i have fitted lexus 430 4pot calipers they are huge put still uses a 43mm piston and black rear brembos, i now seem to have a lot more brake pedal travel and a lot more modulation .so i have to use more pedal for the same braking feel, if that makes sense. i also have ss lines. there not spongy but do feel a bit soft.there is no air trapped as i bleed the brake about 4 times. Then got my local garage to do it just to make sure so i wonder if the wrx sti has a bigger brake master and will it be a direct fit to the br9? gen 5 part number is 26401AJ010 thanks Link to comment Share on other sites More sharing options...
JDMBR9 Posted August 14, 2020 Author Share Posted August 14, 2020 (edited) ive found the answer they have different part number br9 looks like a single piston, i could be wrong. impreza has 2 pistons part number 26401AG050 Edited August 14, 2020 by JDMBR9 Link to comment Share on other sites More sharing options...
Register a new accountSign in
