4g63 swapped legacy 2.5i
hello i need some help! soo i swapped a 4g63 into my legacy rwd now. i need help from some one that knows how to tune. im using the stock ecu and stock subie sensors. i need to get the 4g63 tuned to run with this ecu. iv been messing around with rom raider and it runs when i play with the throttle. i can upload my rom file. if anyone can help. here are some pics of it
http://i67.tinypic.com/2uop8b5.jpg
http://i63.tinypic.com/4kf9fc.jpg
http://www.tuningalliance.com
Mike may be able to help you out.
I sent him an email with this thread.
Edited by Max Capacity
Engine Build - Click Here
Btw, I think you'll have hard time adapting 2.5i ECU to a turbo engine, and a non-Subaru one no less. Not sure if 2.5i ECU can even be flashed with turbo rom, but even if I doubt all the inputs/outputs are there. Surely the harness won't have turbo bits.
I am pretty sure your best bet is a standalone that supports that engine.
Edited by unclemat
I got it running with the MAF unplugged I think it’s all in the tune now. I messed with the ignition timing btw there are 5 maps for it don’t know why. I used a dsm rom and set it up using that. Like I said it starts now and runs. Think it just needs fine tuned. I have to finish some plumping yet. I logged some time and have a file saved of it. I’m good with fab work and can make things work mechanically but when it come too the tune stuff I’m lost. Basically I had to machine a crank and cam trigger wheel to the 4g63. I can put up more pics of the progress that I did. I know there is a lot of people saying wtf haha.
Not so much wtf... More like well done! Interesting swap. Hope that thing doesn’t crank walk it’s way out the front! Best of luck on the rest. Be curious to see how it does on a dyno. What turbo is on it? Edited by Gex
  • 6 months later...
  • 1 month later...
Any updates on this? Very interested if you got this running right.
Also could you please let us know what you have done to get this far? I know I am curious and am sure others are as well.
  • 2 years later...
Update! Motor is in everything works! Check out the YouTube channel M&mbuildz I’ll post some pics up later tonight I’m putting a rear suspension from a 18 sti on it right now I ended up using the Dsm ecu and the legacy ecu to keep thinks happy now I need new wheels 5x114 that clear Brembos using 14 sti Brembos
