kanazteck261 Posted July 13, 2016 Share Posted July 13, 2016 Hello all, Searched alot. All threads i found said it was battery related. Except for one that said it was injector clip related. Manual says it is related to si drive, which was not touched in my install at all. Long story short swapped new block, ewg, air pump delete, electronic boost controller, aos, cobb intake. Once hooking up battery got message in dash and si drive blinks and temperature goes all the way hot. I check battery voltage it is 12.4, i then check starter it has voltage as well and is grounded correctly. I found one connector that was not clipped with exception of clips going to tgvs and previous air pump connectors. Not sure where this goes, but wondering if it is my missing piece...i hope http://uploads.tapatalk-cdn.com/20160712/c62e3635c1573f1e7d999dfcaf60480c.jpg Yellow clip looks like it is grounded to frame but not sure where it clips it. It is located by the power steering reservoir, Any help i appreciate. Thanks Andrew Link to comment Share on other sites More sharing options...
kanazteck261 Posted July 18, 2016 Author Share Posted July 18, 2016 Was missing ground on drivers side by inter cooler. Sent from my HTC6525LVW using Tapatalk Link to comment Share on other sites More sharing options...
RoscoeOutback Posted September 10, 2018 Share Posted September 10, 2018 Can you be more specific about which ground on drivers side Near Intercooler? I am having same issue and it is kicking my butt. Are you talking about the Main Engine Harneas grounding luggs that bolt up to the fuel injector protector, the metal shield that goes around fuel rail? Those Are already connected and right. Thanks Link to comment Share on other sites More sharing options...
RoscoeOutback Posted September 11, 2018 Share Posted September 11, 2018 I believe that the two wire connector between the ABSCM-h/u (and the Power Steering fluid res) is an access lead for the front airbag. My downloaded diagnostic guide says thaT any yellow connector is for the airbag control and access and is strictly DO NOT TOUCH!!!! Would appreciate anybody confirming or refuting this. Thanks Link to comment Share on other sites More sharing options...
kanazteck261 Posted September 11, 2018 Author Share Posted September 11, 2018 That picture doesn't relate to anything, so please disregard. My gound wasn't in right spot. I had tgv deletes, aftermarket fuel regulator, aftermarket intercooler etc and the stock ground position by fuel regulator was no longer useable. Once I got a proper ground I had no issue. However one thing I noticed that could have also been an issue was the power to my obd was loose. I had the plastic piece from under dash off and when I touched the obd cable connector it would flicker on and off my accesport. If that cable is not properly secure I would look into that also. Hope this helps Link to comment Share on other sites More sharing options...
RoscoeOutback Posted September 12, 2018 Share Posted September 12, 2018 Could be. Mine is flaky as well. Sometimes I have a to hold it still to get it to read codes. As I am on day 6 stuck on the side of the road, I will check this immediately. On the bright side: I got to know the folks around here. Will let you know how it goes. Link to comment Share on other sites More sharing options...
