enzotheracer Posted February 11, 2015 Share Posted February 11, 2015 I have a 91 legacy, just picked up an 96. Wiring on the 96 shot. Goal is to swap out the drivetrain. Was wondering if the connectors are the same on the trans and what i have to change wiring for the fuel pump? And is there anything else that I should know? Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 11, 2015 Share Posted February 11, 2015 Read this DIY from surrealmirage.com. http://www.surrealmirage.com/subaru/swap/parts.html Should have almost all the info you need! It was posted by Legacy777 from bbslegacycentral aka Josh. Link to comment Share on other sites More sharing options...
USLiberty Posted February 12, 2015 Share Posted February 12, 2015 I did a fwd to awd turbo swap. I know you will need to swap the whole rear crossmember, fuel tank and gas separator. Not sure if the 96 connectors are the same but it wouldn't surprise me. Link to comment Share on other sites More sharing options...
enzotheracer Posted February 12, 2015 Author Share Posted February 12, 2015 Yrah the 96 is now a donor car. So no problem there. Link to comment Share on other sites More sharing options...
