Nonvteclegacy Posted January 20, 2006 Share Posted January 20, 2006 Does anybody have the HID kit from the factory? If so does you car come with Day time running lamps? I was thinking about getting some HIDs. If I buy an after market HID kit do you think I would need to uninstall my DTRL? DTRL only use 40percent of wattage until you turn your headlight switch on. I was thinking since HIDs have to charge up at 40 percent of the power might make the HID bulbs go out. What do you guys think? Link to comment Share on other sites More sharing options...
gt_ltd Posted January 20, 2006 Share Posted January 20, 2006 search This Space For Rent Link to comment Share on other sites More sharing options...
chuckzul Posted January 20, 2006 Share Posted January 20, 2006 I've been running HIDs for quite some time. Disabled the drls when I installed them, never had any trouble and love the difference HIDs make. Link to comment Share on other sites More sharing options...
Xenonk Posted January 20, 2006 Share Posted January 20, 2006 he's talking about the JDM OEM HID setup.. if you look in the engine bay fuse box, there are two relay plugs for the HIDs.. Personally I stopped half way in researching about the wiring setup differences.. I didnt get far enough to get a hold of the contacts that I needed to even source the JDM HID part numbers and what was involved of installing them into the USDM cars. If you plan on going aftermarket, just disable the DRLs, it's a 5 min job to do that. OFF-TOPIC: NONVTECLegacy, your SN should have been AVCSLegacy Keefe Link to comment Share on other sites More sharing options...
VXCL Posted January 20, 2006 Share Posted January 20, 2006 Just trigger a relay with the oem + lead and power directly off the battery. DRL now triggers my xenon d2s system. works flawless. both myself and another member preadet are enjoying a complete xenon d2s projector retro with this setup. http://www.legacygt.com/forums/showthread.php?t=14544&page=5&highlight=headlamp peace MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
dark_rex Posted January 20, 2006 Share Posted January 20, 2006 does anyone know a place to source the whole HID headlamp unit (JDM) I'd love to just plug n play a whole new assembly, otherwise i'll just have to clear mine and live with projectors. dR Link to comment Share on other sites More sharing options...
Nonvteclegacy Posted January 20, 2006 Author Share Posted January 20, 2006 Here's what I found on a search. If you wanna do an after market plug and play kit. http://www.pimpmyauto.com/H7%20HID%20kit%20install.htm Link to comment Share on other sites More sharing options...
bcbaohio Posted January 20, 2006 Share Posted January 20, 2006 OCDetails has a pretty sweet HID set-up ask him where he got his - here's a link to his website with info about his car: http://www.ocdetails.com/html/2005_legacy_gt.html - "I've worked with better, but not many." Link to comment Share on other sites More sharing options...
boostsr20 Posted January 20, 2006 Share Posted January 20, 2006 OCDetails has a pretty sweet HID set-up ask him where he got his - here's a link to his website with info about his car: http://www.ocdetails.com/html/2005_legacy_gt.html Thats just a drop in aftermarket setup, I have the same one. Really happy with the result. Yes, you do need to disable the DRL's as to not wear out the bulbs. Link to comment Share on other sites More sharing options...
Nonvteclegacy Posted January 20, 2006 Author Share Posted January 20, 2006 Will installing the after market HID kit void anything on the warranty? I still got 9000 more bumper to bumper warranty. Off the subject I'm missing one of the mud flaps on the back. Will they give me a new one under warranty? Does anybody know where I can get OEM parts for cheaper then the Subaru store? Acessorys and stuff. Link to comment Share on other sites More sharing options...
bcbaohio Posted January 20, 2006 Share Posted January 20, 2006 Will installing the after market HID kit void anything on the warranty? I still got 9000 more bumper to bumper warranty. Off the subject I'm missing one of the mud flaps on the back. Will they give me a new one under warranty? Does anybody know where I can get OEM parts for cheaper then the Subaru store? Acessorys and stuff. Whoa, whoa, whoa there buckaroo, that's a whole lot of questions in one post:icon_bigg SOA is pretty rough, if they can trace a system failure back to a particular modification, they will not warranty the part. That being said, example - turbo back exhaust installed on the car and the power window switch breaks. The two systems are not related, so it should be warrantied. Next - turbo back installed and the turbo implodes, no warranty coverage. Oh and the mudflap, kiss the service managers butt and he may cut you a break, but probably not covered. - "I've worked with better, but not many." Link to comment Share on other sites More sharing options...
