mikeydrives1 Posted January 20, 2018 Share Posted January 20, 2018 Hello all, So let me start this off here. I have my trusty 2008 Legacy 2.5i, at around 170k miles and climbing. Recently (few weeks now) , i had an ABS light followed by the ER: SS displayed on my odometer after driving in some pretty decent snow (NJ got pounded where i was). Im no stranger to these things, many a-time ive gone out for good fun in other models (even this one) and packed my wheels and hubs so full of snow, they trip an ABS light. No big deal, you remove the snow, or have it melt away and you're good to go, right? Not this time around. It seems this ABS light has stayed on persistently. I did a little bit of research here and tried a few solutions to no avail so far. 1.) Checked everything and confirmed it was all clear of dirt and debris. No obvious wire breaks , and all 4 wheel bearings are brand new within the last year, so i suspect the ring(s) on them are clean and free of defect. 2.) I read that codes are stored in the TCU. A normal code reader does not seem to recognize or clear it, and using my trusty Tactrix 2.0 and the Romraider logger, i am able to go in and see real-time readings of ECU and TCU, and using the programs option for "read code" on both, it comes back with no codes. 3.) Tried the battery trick, had an excuse to replace it so i took it out and let it sit overnight in my garage, and low and behold, the ABS light with dash ER message still appears. OK, short of just dropping this thing off at a dealer, is there any diagnostic way (i know where my test connectors are) to get this car into some boot mode or something where it will display a code referring to a possible bad sensor? Im starting to lean towards just a totally shorted out wheel sensor at this point which is why the code will not clear at all and remains even after ECU and TCU resets through tactrix. Thanks in advance, and feel free to clunk me over the head with any obviously missed threads already touching upon this.... read quite a few but it always was solved by doing what ive done above... Link to comment Share on other sites More sharing options...
apexi Posted January 20, 2018 Share Posted January 20, 2018 Just out of curiosity, what brand wheel bearings are installed? Link to comment Share on other sites More sharing options...
mikeydrives1 Posted January 21, 2018 Author Share Posted January 21, 2018 Just out of curiosity, what brand wheel bearings are installed? OEM from a local dealership. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted January 22, 2018 Author Share Posted January 22, 2018 Bump for answers. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted January 23, 2018 Author Share Posted January 23, 2018 Bump! Link to comment Share on other sites More sharing options...
mdzowner Posted January 23, 2018 Share Posted January 23, 2018 ive been told sometimes the speed sensors going foul can cause the abs light Link to comment Share on other sites More sharing options...
apexi Posted January 23, 2018 Share Posted January 23, 2018 Maybe give this a try http://legacygt.com/forums/showthread.php/reading-ess-dtc-codes-171935.html Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 23, 2018 Share Posted January 23, 2018 Does your speedometer work? Can you watch live data? If so, monitor vehicle speed and all 4 wheel speeds. Aside from going to a shop and trying their scan tool, it's going to be tough to diagnose. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted January 23, 2018 Author Share Posted January 23, 2018 speedometer works just fine. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted February 2, 2018 Author Share Posted February 2, 2018 The above link has gotten me " C0102 " Link to comment Share on other sites More sharing options...
mikeydrives1 Posted February 2, 2018 Author Share Posted February 2, 2018 The headlight on/off with the 4 clicks of the dash button worked like a charm... code is for left rear sensor. Im wondering why this worked, yet the TCU reading from tactrix wasnt detecting this? Link to comment Share on other sites More sharing options...
ehsnils Posted February 3, 2018 Share Posted February 3, 2018 C0102 ABS wheel speed sensor malfunction (Broken wire, short) Rear ABS wheel speed sensor LH So it should be possible to fix without too much effort. http://www.bedug.com/pics/Subaru/obdcodes_Subaru.txt Link to comment Share on other sites More sharing options...
Dispatch20 Posted February 6, 2018 Share Posted February 6, 2018 I'm not sure if this will be helpful but my Err SS code was caused by a failing abs control module. Debug info here: http://www.subaruoutback.org/forums/showthread.php?t=447257 Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 8, 2018 Share Posted February 8, 2018 Mine was caused when the ABS sensor wire got cut by road debris. I would go to the the indicated wheel (per the code) and trace the sensor back through the wheel well until you find a break, if no break pull the senor out of the hub (single 12mm bolt in the knuckle) if that is cracked replace it. If that is good then your ABS module could be failing. Link to comment Share on other sites More sharing options...
Wagonation Posted February 10, 2018 Share Posted February 10, 2018 Sounds like a bad speed sensor. My shop was able to diagnose 2 bad rear sensors at different times. Not sure how they did it but there is a way apparently. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 12, 2018 Share Posted February 12, 2018 Well what happens is the ABS sensor relays movement, if one wheel isn't moving or being detected as moving it throws the error. So all four wheels are moving AND it gets the input from the speed sensor on the transmission and its happy. One or more breakdowns in that network (ABS + Speed sensor CAN) and your ECU isnt happy Link to comment Share on other sites More sharing options...
mikeydrives1 Posted February 22, 2018 Author Share Posted February 22, 2018 Well, final results: The rear left ABS sensor tip was sheered clean off inside the hub. It appears a small rock made its way in, dinged the protector ring, and proceeded to grind up inside the hub leaving dust, grit and scrape marks all inside. After cleaning it out, i smoothed the dinged up part of the ring and installed the new sensor, and its all good. What are the odds a small pebble can do that? I have not been on any dirt trails in awhile too. Link to comment Share on other sites More sharing options...
