jaronervin Posted April 24, 2019 Share Posted April 24, 2019 Hello! I just bought a 2008 GT. The stereo seems to have an input option for satellite radio, but I don't have the antenna on the windshield, so I assume it was an option not purchased. Has anyone had any success attaching an aftermarket satellite antenna to the stock stereo, so that I can use all the stock buttons? Alternatively, is there a resource where I can find the part # of the OEM antenna, or a site where I can purchase one? TIY! Jay Link to comment Share on other sites More sharing options...
upjeeper Posted April 24, 2019 Share Posted April 24, 2019 do you have an AUX port in your center console? Link to comment Share on other sites More sharing options...
whitetiger Posted April 24, 2019 Share Posted April 24, 2019 you need to buy the Subaru OEM XM unit if you want full XM headunit integration. try ebay, or if you are lucky, an online subaru OE accessories dealer. otherwise, you'll have to go aftermaket Link to comment Share on other sites More sharing options...
apexi Posted April 24, 2019 Share Posted April 24, 2019 https://techinfo.subaru.com/stis/doc/accInstallGuide/057957-H621SXA100190303.pdf The document above lists the part number for the kit as "H621SXA100", but some websites say superseded by "H621SXA101". Link to comment Share on other sites More sharing options...
jaronervin Posted April 25, 2019 Author Share Posted April 25, 2019 do you have an AUX port in your center console? I do, but I'd prefer to work it through the stereo, so I don't have to grab my phone if I want to change stations. Also, I think the subscription is cheaper if I limit it to cars, so I don't mind spending upfront on an antenna to drop the price ongoing. Link to comment Share on other sites More sharing options...
jaronervin Posted April 25, 2019 Author Share Posted April 25, 2019 https://techinfo.subaru.com/stis/doc/accInstallGuide/057957-H621SXA100190303.pdf The document above lists the part number for the kit as "H621SXA100", but some websites say superseded by "H621SXA101". Thank you for that! It looks like I can get the superseded one for a couple hundred bucks, which I think I'm willing to do for the full functionality. However, I've never seen what the antenna actually looks like in the windshield. Is it obstructive? Does anyone happen to have a pic of it installed? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2019 Share Posted April 25, 2019 I bought the oem satellite radio kit back in 2011 and installed it in my 09 Works great. Took. A couple hours to install. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
apexi Posted April 25, 2019 Share Posted April 25, 2019 Not the best pictures, but I'll throw them out there anyway. https://legacygt.com/forums/showpost.php?p=4341034&postcount=6 Also a picture from inside a tribeca in this link, #7 down on the right side. Install instructions say it's the same kit, same antenna. http://www.cars101.com/subaru/tribeca/tribeca2007photos.html Link to comment Share on other sites More sharing options...
Max Capacity Posted April 26, 2019 Share Posted April 26, 2019 I now remember the instructions for the kit had directions for the Tribeca too. It was pretty easy to install, just plug and play mostly. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jaronervin Posted April 29, 2019 Author Share Posted April 29, 2019 From the comments here, I've come to the conclusion that: 1) The OEM antenna is the best option for using the stock functionality 2) It's an install that I'm likely capable of doing on my own. Thanks everyone for the input, I'll let you know how it goes! Jay Link to comment Share on other sites More sharing options...
59ctd Posted April 29, 2019 Share Posted April 29, 2019 You can find the XM receiver module for fairly cheap on ebay. I got one for $20. You will also need the mounting brackets which are also available on ebay. I did not get the OEM window mount antenna. I bought one that needs to be mounted on a flat surface pointing up. I have not installed it yet. Likely I will put the antenna on the dash at the far right or left. Link to comment Share on other sites More sharing options...
59ctd Posted April 30, 2019 Share Posted April 30, 2019 I forgot to mention yesterday that if you go the ebay route you will also need the wiring harness that goes between the XM receiver and the head unit. I have a Grom BT3 bluetooth unit and it came setup with a Y cable to connect the head unit, bluetooth module, and optionally the XM receiver unit. Link to comment Share on other sites More sharing options...
