stuck686 Posted November 14, 2012 Share Posted November 14, 2012 I have trouble reading where the oil is... are you supposed to push it in all the way when you read it?? i am at 1200 into my OCI and it just comes out looking oily everywhere so i cant really tell any tips? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 14, 2012 Moderators Share Posted November 14, 2012 Oil all over the stick means you probably have significant blow-by. could be due to ringland failure, might want to get it checked... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
stuck686 Posted November 14, 2012 Author Share Posted November 14, 2012 i bought it just under a month ago and the compression test was pretty solid, it runs great too. What would i get checked? Link to comment Share on other sites More sharing options...
jasontee1 Posted November 14, 2012 Share Posted November 14, 2012 Make sure your car is not running when you check it clean off the dip stick with a rag then put it all the way in then pull it out and check it Link to comment Share on other sites More sharing options...
BigBlack-V Posted November 14, 2012 Share Posted November 14, 2012 also make sure the motor is cold when you check the motor it is the ideal time to check the oil I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 14, 2012 Moderators Share Posted November 14, 2012 i bought it just under a month ago and the compression test was pretty solid, it runs great too. What would i get checked? did you do a leak-down test? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
stuck686 Posted November 14, 2012 Author Share Posted November 14, 2012 did you do a leak-down test? yes they were all around 139 but cyl 4 was abit lower like 132 yes the car sat for like 4 hours at work and then i cleaned the stick and did it (i know the basics) i just cant see a distinct line. maybe its a bit overfull and the oil is just clean? (amsoil 5-30) Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2012 Share Posted November 14, 2012 Newbie's. remove the o-ring at the top of the dipstick. It seems all boxer engine holds oil up the dipstick tube when the engine is turned off. My B&S boxer engine on the lawn tractor did the same thing. What I used to do before removing the o-ring was, drive to work, park the car on level ground, turn it off, open the hood, pull the dipstick about 2" out, close the hood, go to work, 8 hours later, open the hood, wipe the stick, check the oil. You may find the oil reads in a V on the top side of the stick, flip it over, that the true reading. Welcome to the world of boxer engines... Oh top it off as needed, THESE THINGS USE OIL. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 14, 2012 Moderators Share Posted November 14, 2012 http://lmgtfy.com/?q=check+oil+level+site%3Alegacygt.com read 'dat. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
.Catalyst. Posted November 14, 2012 Share Posted November 14, 2012 I see Max jsut beat me to it - I use his method. Park car and pull dipstick out a couple inches and let the car sit for a while (I usually leave overnight). Then insert and check. Usually differing levels on front to back - I read the lower of the two as the level. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
stuck686 Posted November 14, 2012 Author Share Posted November 14, 2012 will do thanks. i thought there was something cheeky about this Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2012 Share Posted November 14, 2012 I think in my got some new stuff for engine R&R thread I posted a picture of the roughly 45* angle the dipstick enters the oil at. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
subie_dude05 Posted November 14, 2012 Share Posted November 14, 2012 http://legacygt.com/forums/showthread.php/dip-stick-modification-55961.html?t=55961&highlight=dip+stick this too, and the thread makes for a funny read. this with the other method. Link to comment Share on other sites More sharing options...
stuck686 Posted November 14, 2012 Author Share Posted November 14, 2012 lol Link to comment Share on other sites More sharing options...
stuck686 Posted November 14, 2012 Author Share Posted November 14, 2012 one more question - how many quarts should it take with an oil change new normal sized filter? finally got a good read and it is a bit low Link to comment Share on other sites More sharing options...
mwiener2 Posted November 14, 2012 Share Posted November 14, 2012 Oil all over the stick means you probably have significant blow-by. could be due to ringland failure, might want to get it checked... Response fail. Seriously? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
DocHolladay23 Posted November 14, 2012 Share Posted November 14, 2012 one more question - how many quarts should it take with an oil change new normal sized filter? finally got a good read and it is a bit low about 4.5 qts, if you want exact numbers though [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
stuck686 Posted November 14, 2012 Author Share Posted November 14, 2012 about 4.5 qts, if you want exact numbers though i feel like ive read from 4.5 to 5.2. Also on a tangent, to make up 1/4 of the dipstick how much should i put in? in b4 "basic math" does half of the diptick correlate to dividing 4.5/2 perfectly? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2012 Share Posted November 14, 2012 4.2 qt's Here's why the stick is hard to read, see how it goes into the pan. http://i185.photobucket.com/albums/x40/92Si/DSCN4718.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted November 15, 2012 Share Posted November 15, 2012 I believe its ~.75qt on the display to get the dipstick to read from low to full. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
CAMS Posted November 15, 2012 Share Posted November 15, 2012 From my experience in the past the full to add line is about one qt. However the above post seems more accurate as far as the sube is concerned. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 15, 2012 Moderators Share Posted November 15, 2012 Response fail. Seriously? Lol, no--not even remotely serious. This is just one of those questions that is answered in a billion threads--our dipsticks suck, read as best you can after the oil settles, add as needed. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
stuck686 Posted November 15, 2012 Author Share Posted November 15, 2012 Lol, no--not even remotely serious. This is just one of those questions that is answered in a billion threads--our dipsticks suck, read as best you can after the oil settles, add as needed. u mad the forum is being used for its purpose? its not a wikipedia Link to comment Share on other sites More sharing options...
SCASEYS Posted November 15, 2012 Share Posted November 15, 2012 ^I'm sure he's just frustrated w/ the amount of n00b posts w/o checking the forum using the search features that are provided. Learn how to navigate the forum w/o posting more of the same over and over I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 15, 2012 Moderators Share Posted November 15, 2012 ^i'm sure he's just frustrated w/ the amount of n00b posts w/o checking the forum using the search features that are provided learn how to navigate the forum w/o posting more of the same over and over This. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
