xt2005bonbon Posted September 11, 2019 Share Posted September 11, 2019 As the title says, I have found some engine builders (on ebay ) installing NPR pistons and rings in EJ257 blocks. But info on the web is scarce about this brand. Is there anyone on the forum who has any info about this brand? Also, anyone using these for a while? Are there any better than OEM (i.e. less prone to fail due to detonation)? Here is the US version of their site: http://www.npramerica.com/nprofamerica_product.html Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 11, 2019 Share Posted September 11, 2019 Bored so I decided to do a little bit of searching on the internet. Apparently there is two different NPR Brands. Nippon Racing and Nippon Piston Rings. Nippon Piston Ring is supposedly Japanese brand comes in a Yellow Box with NPR circled. People used these to build Hondas and DSM and it raises compression. While Nippon Racing comes in a white box with npr in black lettering. These are Chinese knock offs. You might of read some of this on the internet also, but if you didn't thats what I found out about them As for them in our cars? I believe most people will just get oem or forged. Good luck with the search. Link to comment Share on other sites More sharing options...
pog0 Posted September 11, 2019 Share Posted September 11, 2019 Would be best to skip it. When I researched replacing my block, it was cheaper/better just to get an OEM EJ257 block. If you are going for power, rebuild with forged. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2019 Share Posted September 11, 2019 You've been around here for awhile, surely you've read my thread in my click here link in my sig. What are your HP goals then lead you to thinking you need pistons ? pog0 is telling you the same thing my trusted machine shop told me back in 2012. That's the same shop that helped us build the 1.6L single cam Civic to 586whp. I trusted what they said, 125,000 miles later the EJ257 is still running great. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 11, 2019 Author Share Posted September 11, 2019 I am almost positive I need a shortblock. But I don't really want to replace it with more of the same, which can 'easily' suffer from cracked ringland due to detonation. I want something a little tougher which does not hurt the bank too much. This guy on ebay, who supposedly has rebuilt lots of engines, sells ej257 blocks with these NPR pistons and rings, ARP ROD BOLTS, king race bearings, including new oem oil cooler, oem oil pump, and oem water pump for 1950$ including shipping. He claims these NPR pistons and rings are much tougher than oem... Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2019 Share Posted September 11, 2019 It's not the engine, its the "tune". 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 12, 2019 Author Share Posted September 12, 2019 I know. But these stock pistons are a bit too sensitive... And we had the same tuner. Link to comment Share on other sites More sharing options...
moral hazard Posted September 12, 2019 Share Posted September 12, 2019 I'd suggest watching a few of this channels videos , they often end up rebuilding engines after someone took short cuts or from poor workmanship. https://m.youtube.com/user/bollunjanumberone Reason I bring this up, I would not expect great quality work from someone flogging engines they rebuild, on eBay. You won't know what you're getting unless you take it apart (which obviously you wouldn't normally do). I'm sure NPR pistons and rings are fine if they are properly installed and all clearances checked with the right measurement tools. I would not trust an eBay seller to do that correctly... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 12, 2019 Author Share Posted September 12, 2019 Yeah. I understand. I'll check your video. Link to comment Share on other sites More sharing options...
Darth SpecB Posted September 12, 2019 Share Posted September 12, 2019 I have used these piston rings in my engine. About 12k miles on them atm. About 0.5 qt oil consumption per 3k miles. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 12, 2019 Author Share Posted September 12, 2019 Which pistons did you go with? Any mods to your car? Link to comment Share on other sites More sharing options...
Darth SpecB Posted September 13, 2019 Share Posted September 13, 2019 Stock pistons, arp head studs, sti 11mm oil pump, king performance race bearings, intake, cnt downpipe, magnaflow exhaust. Built for reliability, not power. Dynoed at 255whp. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 13, 2019 Author Share Posted September 13, 2019 I see. What made you select these rings? And here is the ebay sale I was referring to: https://www.ebay.com/itm/SUBARU-WRX-STI-EJ257-COMPLETE-SHORTBLOCK-ARP-ROD-BOLT-NPR-PISTONS-OIL-WATER-PUMP/273844308285?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908131621%26meid%3Dd72a33d3b2df407189afe18999cb478b%26pid%3D100678%26rk%3D3%26rkt%3D15%26sd%3D141677451542%26itm%3D273844308285%26pmt%3D0%26noa%3D1%26pg%3D2481888&_trksid=p2481888.c100678.m3607&_trkparms=pageci%3A613144e6-d62a-11e9-adfd-74dbd18013c9%7Cparentrq%3A2acf9b7416d0aadcc7867a9effb0a7c1%7Ciid%3A1 Link to comment Share on other sites More sharing options...
Tehnation Posted September 13, 2019 Share Posted September 13, 2019 BC Stage 3 Cams BC0622 $650 BC Springs BC0600 $215 Manley Turbo Tuff Extreme Duty Pistons 632800CE-4 99.50 -17cc 8.5cr $650 Manley H-Tuff Rods 15024-4 $275 ARP Head Stud Kit 260-4701 $185 Subaru STi 11mm 15010AA360 Oil Pump $130 Subaru 10105AA720 Engine Gasket Kit $235 Cost to rebuild longblock, includes hot tank and 10k rpm balance, with King Bearings $1815 and whatever extra if they need to readjust the heads after assembling longblock. Total $4155 That's what I paid to get a rebuilt longblock. Haven't started it yet so.... who knows lol! Link to comment Share on other sites More sharing options...
Tehnation Posted September 13, 2019 Share Posted September 13, 2019 I like Manley pistons, tight tolerances and forged. Link to comment Share on other sites More sharing options...
Tehnation Posted September 13, 2019 Share Posted September 13, 2019 https://www.ebay.com/itm/2004-2013-Subaru-Forester-XT-EJ25-2-5L-Impreza-Baja-EJ20x-EJ255-Engine-Motor/233310326447? Used longblocks for 1350 !!! OMG !!! These motors are getting cheaper and cheaper. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 13, 2019 Author Share Posted September 13, 2019 (edited) I saw one from a jdm vendor in immaculate condition. Complete engine with the turbo, intake manifold, etc.... 55k miles. 1300$! Supposedly passed compression test. And it's local! Edit: never mind. it is an ej20x Edited September 13, 2019 by xt2005bonbon Link to comment Share on other sites More sharing options...
Tehnation Posted September 13, 2019 Share Posted September 13, 2019 yea, stay away from that 2.0 nonsense. So you don't know what is exactly wrong with your block but its still operational? If that's the case your in my shoes exactly... I couldn't get my car etuned because I was chasing some dragon, so I decided to pull my block apart completely to find the issue, and I found I had cracked ringlands. If you catch the problem before it explodes then your in good shape. My cylinder walls were fine as well as everything else, so it was a simple rebuild. It gets expensive when you have to fix spun bearings, gouged cylinder walls, bad cylinder heads, etc. Have you pulled the motor or torn it down? Link to comment Share on other sites More sharing options...
Tehnation Posted September 13, 2019 Share Posted September 13, 2019 And when i linked the used block , i was not trying to imply to install a used block! For the experienced thats a great price, if its in working order, to start a project, especially if it comes with all the parts in the picture. New heads are like 600 a piece, and block halves are another 1200 or so. So if your were planning to rebuild a motor, that's not a bad price to pay for heads and block. **** the old internals! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 13, 2019 Author Share Posted September 13, 2019 My engine is using a lot of oil, despite the spark plugs looking OK, and barely any oil in the intake track and intercooler. I have personally adjusted my valve clearances (on the driver side) 40k ago. Spark plugs are somewhat new, coils are fine. I am almost positive injectors are fine. Did a compression test a month ago. Ended up getting 115 on both #2 and #4 and 130 on #1/#3. BtSsm does report at times some roughness on #4 and rarely on #2. But last two weeks, engine remained off as I was going to replace my leaky radiator. When it was ready to fire her up, she definitely sounded like a low comp engine (not first time she does that after remaining off for several weeks). She did start fine though with misfires on #4 which went away ~5-8sec after start up. Car runs fine. Does not throw a cel since misfire count is rare and very low when it happens. But I know something is up. Aaaaand I just swapped my good ol vf40 with a JMP vf52 . Link to comment Share on other sites More sharing options...
Tehnation Posted September 13, 2019 Share Posted September 13, 2019 have you done a compression and/or leakdown test? thats pretty much the only way to diagnose a shortblock. Did you retune the car after installing a new turbo? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 13, 2019 Author Share Posted September 13, 2019 Yeah. As I said, I did a compression test yielding smaller numbers on the driver side compared to the passenger side. This was done cold. Did not do a leakdown test as I usually expect to leak at the rings when done cold (this happened to me before even though I had a super tight valve). Currently self tuning for the new turbo with the help of an experienced Subaru enthusiast Link to comment Share on other sites More sharing options...
Tehnation Posted September 14, 2019 Share Posted September 14, 2019 if your not driving the car, then i would pull the motor and pull it apart to see whats really going on. The condition of the cylinder walls, journals etc. should give you a better idea of what route to take. Link to comment Share on other sites More sharing options...
Nonamedude Posted September 14, 2019 Share Posted September 14, 2019 Is there a reason you're not just rebuilding your block with better pistons? Is it just a cost thing and hoping these would be a good deal? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Darth SpecB Posted September 15, 2019 Share Posted September 15, 2019 I just wanted to throw some new rings on and those were the only ones I could find. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
