maddoc Posted October 23, 2019 Share Posted October 23, 2019 Hi All, Picking up a 2013 Premium 2.5i with a blown CVT as a project/daily driver. I'm looking to find out what transmissions out of other Subarus would be compatible with this model. In the past (eons ago...), it was pretty easy to find compatible transmissions among Subarus. Now, there seems to be very little knowledge. I came across this Wiki: https://en.wikipedia.org/wiki/List_of_Subaru_transmissions#Subaru_Lineartronic_CVT_TR690_and_TR580 Can I basically get any of the TR580s and be ok? Thanks! Link to comment Share on other sites More sharing options...
Alexmed2002 Posted October 23, 2019 Share Posted October 23, 2019 Hi All, Picking up a 2013 Premium 2.5i with a blown CVT as a project/daily driver. I'm looking to find out what transmissions out of other Subarus would be compatible with this model. In the past (eons ago...), it was pretty easy to find compatible transmissions among Subarus. Now, there seems to be very little knowledge. I came across this Wiki: https://en.wikipedia.org/wiki/List_of_Subaru_transmissions#Subaru_Lineartronic_CVT_TR690_and_TR580 Can I basically get any of the TR580s and be ok? Thanks! Obviously your best bet would be to get a cvt from the same model year, with low mileage. I'm not quite sure if it's possible, but an idea I've thought about is maybe you could put in a manual tranny if it won't be killer on the wallet? Link to comment Share on other sites More sharing options...
dgoodhue Posted October 23, 2019 Share Posted October 23, 2019 How many miles are on the car? The CVT warranty was extended. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 23, 2019 Share Posted October 23, 2019 It would definitely be worth trying to get it warrantied. Link to comment Share on other sites More sharing options...
maddoc Posted October 23, 2019 Author Share Posted October 23, 2019 Obviously your best bet would be to get a cvt from the same model year, with low mileage. I'm not quite sure if it's possible, but an idea I've thought about is maybe you could put in a manual tranny if it won't be killer on the wallet? Same model year legacy is impossible to find, which is why I'm trying to branch out. How many miles are on the car? The CVT warranty was extended. Over 120k Link to comment Share on other sites More sharing options...
Alexmed2002 Posted October 23, 2019 Share Posted October 23, 2019 Same model year legacy is impossible to find, which is why I'm trying to branch out. Over 120k Dang that's a bummer, the warranty only goes up to 100K if I remember correctly Link to comment Share on other sites More sharing options...
NVAKeith Posted October 23, 2019 Share Posted October 23, 2019 2014 Legacy might be the same, look into that. Outbacks have a different final drive ratio. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 23, 2019 Share Posted October 23, 2019 2013-14 CVT are the same for the 2.5L 2015+ will not work <2013 will not work. Same CVT model from other model will not work as the final drives are most likely different Link to comment Share on other sites More sharing options...
FLlegacy Posted October 23, 2019 Share Posted October 23, 2019 Same model year legacy is impossible to find, which is why I'm trying to branch out. Over 120k You aren't looking very hard, there is an entire page of listings on http://www.car-part.com Link to comment Share on other sites More sharing options...
NVAKeith Posted October 23, 2019 Share Posted October 23, 2019 You aren't looking very hard, there is an entire page of listings on http://www.car-part.com Wow you’re not kidding. There are even one near MD with only 17k miles on it. https://imageappky.car-part.com/image?seller=1345&partsourceid=1345&partGUID=1345-pa09-1000617251&vehicleGUID=1345-pa09-VRB299&display=2014%20Subaru%20Legacy%20Transmission%20Assembly-Stock%23%20RB299 Link to comment Share on other sites More sharing options...
maddoc Posted October 23, 2019 Author Share Posted October 23, 2019 2013-14 CVT are the same for the 2.5L 2015+ will not work <2013 will not work. Same CVT model from other model will not work as the final drives are most likely different So to confirm, if I've got a 2013 2.5i (2.5L), a 2014 CVT out of a 2.5i will work. You aren't looking very hard, there is an entire page of listings on http://www.car-part.com I was looking specifically for a 2013 transmission because I did not know if there's any compatibility across the years. Also, based on all the issues with the CVT, I'm also looking for a low mileage CVT. 100k + miles is not something I want to get. Wow you’re not kidding. There are even one near MD with only 17k miles on it. https://imageappky.car-part.com/image?seller=1345&partsourceid=1345&partGUID=1345-pa09-1000617251&vehicleGUID=1345-pa09-VRB299&display=2014%20Subaru%20Legacy%20Transmission%20Assembly-Stock%23%20RB299 So when I search for a 2013 in car-part, it doesn't show any 2014s. Typically if there's compatibility, they will list. Appreciate all the help folks, it's been awhile since I've own a Subaru. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 23, 2019 Share Posted October 23, 2019 So to confirm, if I've got a 2013 2.5i (2.5L), a 2014 CVT out of a 2.5i will work. I was looking specifically for a 2013 transmission because I did not know if there's any compatibility across the years. Also, based on all the issues with the CVT, I'm also looking for a low mileage CVT. 100k + miles is not something I want to get. So when I search for a 2013 in car-part, it doesn't show any 2014s. Typically if there's compatibility, they will list. Appreciate all the help folks, it's been awhile since I've own a Subaru.Theres an option usually to show interchange years from min to max. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 23, 2019 Share Posted October 23, 2019 So to confirm, if I've got a 2013 2.5i (2.5L), a 2014 CVT out of a 2.5i will work. I was looking specifically for a 2013 transmission because I did not know if there's any compatibility across the years. Also, based on all the issues with the CVT, I'm also looking for a low mileage CVT. 100k + miles is not something I want to get. So when I search for a 2013 in car-part, it doesn't show any 2014s. Typically if there's compatibility, they will list. Appreciate all the help folks, it's been awhile since I've own a Subaru. I am not aware of any changes in the drive train between 13 and 14 so yes it will work. Link to comment Share on other sites More sharing options...
maddoc Posted October 23, 2019 Author Share Posted October 23, 2019 Theres an option usually to show interchange years from min to max. Yeah, It only shows 2013 Legacies. I am not aware of any changes in the drive train between 13 and 14 so yes it will work. Any documentation on that (Just trying to make sure before I go buy a 2014 transmission) Link to comment Share on other sites More sharing options...
FLlegacy Posted October 23, 2019 Share Posted October 23, 2019 Yeah, It only shows 2013 Legacies. Any documentation on that (Just trying to make sure before I go buy a 2014 transmission) https://parts.subaruonlineparts.com/oem-parts/subaru-trans-axle-31000aj130?c=Zz1hdXRvbWF0aWMtdHJhbnNtaXNzaW9uJnM9YXV0b21hdGljLXRyYW5zbWlzc2lvbiZsPTImbj1Bc3NlbWJsaWVzIFBhZ2UmYT1zdWJhcnUmbz1sZWdhY3kmeT0yMDEzJnQ9Mi01aS1wcmVtaXVtJmU9Mi01bC1oNC1nYXM%3D Link to comment Share on other sites More sharing options...
