FJuan Posted May 2, 2017 Share Posted May 2, 2017 It sounds and feels like the rear driver side CV joint is bad. When I turn to the right under slight throttle I hear a fairly loud metal click...click...click...click sound. It's not the wheel bearing as I just replaced that last month thinking it was that, but it's not. Has anyone else have issues with their rear CV joint? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2017 Share Posted May 2, 2017 I know I'm not around here much... but I think you are the first. Somebody should give you a cookie... I have been wondering when mine were going to have issues...I hope your not starting something here. LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted May 2, 2017 Author Share Posted May 2, 2017 I know I'm not around here much... but I think you are the first. Somebody should give you a cookie... I have been wondering when mine were going to have issues...I hope your not starting something here. LOL It's odd, because I haven't seen any other member with this problem in the rear CV too. Maybe my car is that odd ball. Over a month ago it was a slight clicking sound under tight turns, but now it's clicking every time I turn to the right. Not much sound going straight, but every once in a while I'll hear a slight clicking. That leads me to believe it's the CV joint. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 3, 2017 Share Posted May 3, 2017 That is the sound a CV makes when its bad, as you know. Like you I'm having a hard time believing its a rear CV. I would think the next step would be to have a good look at it and see if there's any exterior indication that its bad. Have to ask, your sure its not the front ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted May 3, 2017 Author Share Posted May 3, 2017 It's definitely the left rear, going to pull it this weekend and have a look at it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
imprezkid Posted May 15, 2017 Share Posted May 15, 2017 I'm having this same problem, metal clicking while turning right under throttle. Left rear inner CV seems to have too much play. Problem is now finding a replacement axle/parts? Apparently no one sells these parts... Link to comment Share on other sites More sharing options...
FJuan Posted May 15, 2017 Author Share Posted May 15, 2017 I've been searching, but have found axles for auto trans. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
imprezkid Posted May 15, 2017 Share Posted May 15, 2017 I am a auto, but a 5eat which i believe is different than a 4eat. I'm probably going to try to find an oem being parted, sounds like they don't fail often. My car gets lowered and raised every year so i'm sure that is hard on the rear axles. Link to comment Share on other sites More sharing options...
imprezkid Posted May 15, 2017 Share Posted May 15, 2017 I am pretty surprised that 4eat, 5eat, & 5mt would be different Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2017 Share Posted May 15, 2017 read post #165 http://legacygt.com/forums/showthread.php/oem-online-subaru-parts-vendors-list-42243p5.html axles are the same. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted May 15, 2017 Author Share Posted May 15, 2017 Thanks Max, but our issue is the left rear axle. You question Benny regarding the front axles, which is good info to know. I search their site and they have the rear axles for $350.00. Found a member doing a full part out with the same year and trans, seeing if he still has the rear axles. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2017 Share Posted May 15, 2017 The point is look around and see if the rear axles for the different cars are the same part number. I'll bet a GT with a 5eat is the same rear axle as the 2.5i with a 5mt...or a GT with a 5mt. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted May 15, 2017 Author Share Posted May 15, 2017 Found some rear axles on PartsGeek.com My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2017 Share Posted May 15, 2017 Is it just me or does the PartsGeek link take you to a ebay, and other page ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted May 15, 2017 Author Share Posted May 15, 2017 Is it just me or does the PartsGeek link take you to a ebay, and other page ? Oh yeah that's weird, I copied the address of the axles on PartsGeek. I'll delete the link for now until I can get a proper address up. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2017 Share Posted May 15, 2017 I would hope by now that most people know how to do a google search for what they want...yea right... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
imprezkid Posted May 16, 2017 Share Posted May 16, 2017 Looks like i'm looking for an axle out of any Auto legacy/outback from 05-09, shouldn't be too hard to find! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 16, 2017 Share Posted May 16, 2017 Most junk yards will have one, you could rebuild with OEM parts and swap it out with your bad one. Or rebuild yours. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
imprezkid Posted May 16, 2017 Share Posted May 16, 2017 Found one for $50 at a local junk yard w/ 62k miles, pretty good chance of being better than mine with 212k rough ones. Link to comment Share on other sites More sharing options...
FJuan Posted May 16, 2017 Author Share Posted May 16, 2017 That's good, I'll be going that route if I don't here back from a forum member that is parting out his car. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
FJuan Posted June 17, 2017 Author Share Posted June 17, 2017 Bought a reman through Parts Geek, fit perfect and fixed the problem. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
