ItsGULO Posted October 27, 2019 Share Posted October 27, 2019 (edited) Hey Ive got a problem with my Subaru B4 2011 There is 3 warning lights and after about 10 mins of drive another one turning on aswell - Check engine light - AT Oil temp (flashes) - Traction control - Handbrake - the word '"CRUISE" (flashes above km's travelled) This problem disable the AWD (That means the car is 2X4 instead of 4X4) and the Cruise control. I heard its a common issue with this model but i didnt found a spesific answer to how to fix it. I hope to find a solution to this problem here. thanks (I dont have any mechincal background) Edited October 27, 2019 by ItsGULO Link to comment Share on other sites More sharing options...
dgoodhue Posted October 28, 2019 Share Posted October 28, 2019 You have a check engine light and the cluster is alerting you with traction, cruise, brake lights. The code(s) need be read to do any diagnosis. Link to comment Share on other sites More sharing options...
Alexmed2002 Posted October 28, 2019 Share Posted October 28, 2019 You have a check engine light and the cluster is alerting you with traction, cruise, brake lights. The code(s) need be read to do any diagnosis. Yup, with a scanner. Link to comment Share on other sites More sharing options...
ripstik Posted October 29, 2019 Share Posted October 29, 2019 I don't think that there is an electronic way for the car become 2 wheel drive, that could only happen mechanically. what makes you think its only driving 2 wheels? Link to comment Share on other sites More sharing options...
Humble Rumble Posted October 29, 2019 Share Posted October 29, 2019 Hold up. Can you tell us what country you're located in and what model and trim your car is? You have a 240 km/h speedo, which would indicated a 2.5i to me, but very nearly a 7k redline. I've done extensive research into different cluster combinations from around the world and every 2.5i I've seen has a 240kmh speedo and a 6.4k redline. Even the GT's and tS have only a 6.5k redline. I've never seen a 5th gen with a redline at nearly 7k. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
GTEASER Posted October 29, 2019 Share Posted October 29, 2019 I'm guessing its and FA20F motor with a 6700 rpm redline. http://mywikimotors.com/subaru-fa20/ https://en.wikipedia.org/wiki/Subaru_FA_engine GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Humble Rumble Posted October 29, 2019 Share Posted October 29, 2019 I'm guessing its and FA20F motor with a 6700 rpm redline. http://mywikimotors.com/subaru-fa20/ https://en.wikipedia.org/wiki/Subaru_FA_engine I don't believe so. He's in a 2011, to my knowledge they only put the FA20 into post-facelift models, and even then, he's in a non-turbo model from everything I can see. It's not a JDM version, as pre-facelift clusters there were all only 180 kph (tS was 260 kph). From everything I've found, 240 kph speedos are only on non-turbo models, but I'd be more than happy to learn something new. That would just mean that Subaru made even more variants of clusters I wasn't aware of. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
ItsGULO Posted October 31, 2019 Author Share Posted October 31, 2019 Hold up. Can you tell us what country you're located in and what model and trim your car is? You have a 240 km/h speedo, which would indicated a 2.5i to me, but very nearly a 7k redline. I've done extensive research into different cluster combinations from around the world and every 2.5i I've seen has a 240kmh speedo and a 6.4k redline. Even the GT's and tS have only a 6.5k redline. I've never seen a 5th gen with a redline at nearly 7k. Im live in Israel, I dont Know the exact model but its B4 2011 TOP, and i think its only 2.0 and not 2.5 Link to comment Share on other sites More sharing options...
