Idaho subaru Posted February 1, 2014 Share Posted February 1, 2014 Hey everyone, Just thought I'd update a cam sensor problem I had with my '97 wagon awhile ago. Here is the original thread- http://legacygt.com/forums/showthread.php/1997-legacy-wagon-cam-sensor-issue-212267.html?t=212267 So for whatever reason the original picture isn't working in the above thread so I'll repost that. Basically my car would run good then bad, I'd get a PO341 code sometimes, but not always. I had tested and checked everything else and narrowed it down to the cam sensor. I bought a new cam sensor, and had all the same issues. After tinkering for awhile, I found the cam sensor, new or old, needed to be cocked to one side a little and the car would run perfect. So I experimented with different combinations of "shims" until I found the sweet spot. http://i1270.photobucket.com/albums/jj605/Idahorec/97%20Legacy%20Wagon/image_zps72ae30fb.jpg That worked great, drove it for another month or so, then the headgasket presented itself and I pulled the motor to do gaskets, seals, timing, clutch, ect... So anyhow, I was kind dreading doing all this work to the motor, then having the same issue with the sensor. So I figured to only thing I could try, was to use a different cam pulley when I put it back together. I put a different pulley on and did not install my "shims". So the moment of truth came a few days ago when I fired it up....she runs perfectly! Without the need for any Macgyvering. I don't know exactly what was wrong with the old pulley, there are no obvious flaws on the pickup nodes, I did not check for straightness, but that could be a possibility. Just wanted to post something on it in case someone else has mysterious cam sensor problems that don't make any sense, you might want to look at your pulley as a possible culprit? Link to comment Share on other sites More sharing options...
spooln30 Posted February 1, 2014 Share Posted February 1, 2014 Can you post a few pics of the suspect cam gear? Link to comment Share on other sites More sharing options...
Idaho subaru Posted February 2, 2014 Author Share Posted February 2, 2014 Can you post a few pics of the suspect cam gear? Here is one, I think it is of its best side, but if you're thinking of a different angle or something, let me know and I can take more. http://i1270.photobucket.com/albums/jj605/Idahorec/9CBDBAE3-D18D-49AB-9C09-2872EE463767-431-0000012B516713D2_zpsc4a67ef7.jpg The bright spots on the pickups are from when I was originally testing shim placement. I angled the sensor a little to much a couple times and rubbed them. Link to comment Share on other sites More sharing options...
