nick916 Posted December 9, 2013 Share Posted December 9, 2013 I have an 05 LGT and want to put in the catless uppipe I have which is from an 07 outback xt. I'm wondering if anyone has had any experiences with smog and this setup with the 2.2 ohm resistor in the EGT. My opposition to Cobb AP to clear the codes is that I would want to unmarry and sell the AP when I sell the car with no CEL. I was hoping that an OEM subaru uppipe with a resistor mod would be a permanent smog-friendly mod. Would most legal smog places pass it? I'm in Sacramento. Link to comment Share on other sites More sharing options...
FJuan Posted December 9, 2013 Share Posted December 9, 2013 You'll be fine. I've been through 2 smog tests with a gutted UP and Stage 1 tune, passed every time. All they really look for is a cat in the downstream pipping. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted December 9, 2013 Share Posted December 9, 2013 Depends on how knowledgable your smog tech is on your model year. Also how well you hide the resistor mod. I just went through the same debate and decided to gut the 06 up I have and place the EGT back in the pipe. After smog I may pull the EGT plug and place a DP on this car but that will depend on other factors in my life. For now I'm 99% sure my car will pass with the AP un married. Link to comment Share on other sites More sharing options...
nick916 Posted December 9, 2013 Author Share Posted December 9, 2013 I'm a noob to all this but I thought the only ways to not get a CEL with a catless uppipe on an 05 or 06 are a tune or resistor mod... Link to comment Share on other sites More sharing options...
FJuan Posted December 9, 2013 Share Posted December 9, 2013 That's correct. The resistor mod is a lot easier and cheaper to do. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted December 9, 2013 Share Posted December 9, 2013 Resistor mod tells the ECU there is one reading. If I remember right it was static 1320 degrees. No CEL thrown for removing the EGT if it reads the resistance. CAT is just there to heat up the gasses faster during warm up. Confirmed here the ECU is only using the EGT as a fail safe, probably go into limp mode if it got too hot for a long period. No tune perameters are based off of the EGT temp. Link to comment Share on other sites More sharing options...
nick916 Posted December 9, 2013 Author Share Posted December 9, 2013 Thanks so much guys! Link to comment Share on other sites More sharing options...
