bombpockets Posted July 8, 2013 Share Posted July 8, 2013 I'm in the process of replacing my struts/springs and I'ts all been smooth sailing except I can't get the brake lines off the struts.. I've seen clips on other cars, but there seems to be no easy way in the case. help? Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 8, 2013 Share Posted July 8, 2013 I'm pretty sure you have to saw/cut through the tab that holds them. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted July 9, 2013 Share Posted July 9, 2013 I must not be remembering right, but I could swear when I replaced my struts, I was able to just feed the brake line back out through the tab that holds them... ...am I making that up? I don't remember any cutting or sawing. That sounds rather barbaric! Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted July 9, 2013 Share Posted July 9, 2013 I usually just cut the tab, bend them, & remove the line. Link to comment Share on other sites More sharing options...
gergeek Posted July 13, 2013 Share Posted July 13, 2013 just use vice grips and bend the tab off that holds the brake line to your old strut. and then you can reattach them with zip ties latter on if you want to save time. or remove the line from the brakes, and twist the piping around and through the brake line holder......you will need to bleed your brakes afterwards...hence y i took the first option. Link to comment Share on other sites More sharing options...
johnegg Posted July 14, 2013 Share Posted July 14, 2013 zip ties can work. i suspect they will not last as long as the metal brackets. but as long as you are under your car on a regular basis, no worries. or you can cut the bracket , that's what i do. the bracket is square-ish with the line thru the center. on the side opposite from where it attaches to the strut, cut out a center section wide enough to slide the brake line through. this turns the square into a "U" shape with the bottom of the U attached to the strut. slide out the brake line and replace the strut. the bracket and the retaining clip are such that you can reassemble the brake line and they will hold it in place even with the 'cut out'. or you can disconnect the brake line from the caliper and feed it through the bracket on the strut. after the re-assembly you just bleed the brakes. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted July 14, 2013 Share Posted July 14, 2013 Okay, so what I said above, I presume is the "correct" method, though it seems everyone here is too lazy to do it that way I just see it as a good opportunity to bleed the brakes! Link to comment Share on other sites More sharing options...
Zues Marine Posted July 14, 2013 Share Posted July 14, 2013 work smarter, not harder! Link to comment Share on other sites More sharing options...
bombpockets Posted July 20, 2013 Author Share Posted July 20, 2013 Haha sorry for the slow replies, guys. I'm new to forums. Anyway, I ended up cutting and bending the tabs it worked great, although I was terrified of cutting the break lines. Link to comment Share on other sites More sharing options...
