cybaster Posted July 12, 2017 Share Posted July 12, 2017 Hi everyone, I just recently stumbled on a 2008 Spec B with a blown turbo chassis and engine 180k miles exterior seems to be in decent condition but interior have a few pieces broken the seller says that his mechanic said the turbo is blown due to oil starvation. car can run but won't build boost past 25 mph So would you guys do it? or would you pass? also if engine is in ok condition (no visible damages, cracks) would it be wise to completely drain the oil pan, baffle, replace oil cooler? anything else i should be aware of when I go check out the car? Thanks Link to comment Share on other sites More sharing options...
cybaster Posted July 12, 2017 Author Share Posted July 12, 2017 sorry, should've read reading the turbo failure wiki http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html ------ aside from this, any other tips/info? Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted July 12, 2017 Share Posted July 12, 2017 still being driven with an oil starved turbo, more than likely needs a full engine rebuild. Link to comment Share on other sites More sharing options...
cybaster Posted July 12, 2017 Author Share Posted July 12, 2017 as far as i know it has't been driven much after the failure i'm in the process of finding out more info and taking a look at the fluids myself as well. but its not like i can change the oil there to inspect the metal content though... Link to comment Share on other sites More sharing options...
Max Capacity Posted July 12, 2017 Share Posted July 12, 2017 If you buy it...make sure you get a good warranty with it or you could be the next...Hey I just bought this car and on the drive home the engine blew...now what do I do... I see you had Mike tune your 05, talk to him about this car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sshole Posted July 13, 2017 Share Posted July 13, 2017 If you can get the car for less than its value in scrap, then go for it. Otherwise, you'll be in for a nice surprise. Link to comment Share on other sites More sharing options...
jciscott Posted July 13, 2017 Share Posted July 13, 2017 When the turbo went on my 2008 at 140K mi, it was quick, driving home from dinner out. It started to rattle, then bang all in 10 min. I nursed it home, and found the turbo was starved for oil due to the dirty screen. The turbo bearing on the hot side locked up, and the shaft snapped. I got a new turbo, cleaned everything up and changed the oil. I am 26k miles since without incident. Link to comment Share on other sites More sharing options...
