itsfrancis6 Posted January 7, 2018 Share Posted January 7, 2018 New member here. I have a 2014 Subaru Legacy without a turbo. My wife was driving home from work yesterday and the CEL, broken and cruise control lights kept blinking. This morning when we started up the car all the lights were off. Drove for 30 minutes without any issue. Came to Pep boys and they pulled a P0011 code. I sifted through some of the threads and everyone that has the code has had a turbo. I haven't seen any for a non turbo legacy. We live in western New York where it's been around 1 degree for the last week. The only thing I did was kick the snow out of the wheel wells. Appreciate any guidance. Link to comment Share on other sites More sharing options...
coco26 Posted January 7, 2018 Share Posted January 7, 2018 P0011 is related to camshaft position/AVCS system performance. Taken from a post on NASIOC, check these things: A) Low oil levels B) Dirty or contaminated oil C) Low oil pressure D) Oil blockage E) Incorrect camshaft timing Because of temps, I would lean towards it being an oiling problem. Check the level, and if its ok and the car is still running correctly, you can rule out anything major. As long as it hasn't come back since, I would monitor it until it gets a little warmer. If it does come back, I would consider the possibility of a blockage. This is common on turbo cars because they have more places/filters for blockages to occur. Link to comment Share on other sites More sharing options...
itsfrancis6 Posted January 7, 2018 Author Share Posted January 7, 2018 Thanks for the advice. Car only has 18k miles. Last oil change was 4k miles ago with synthetic. Will check levels later today Link to comment Share on other sites More sharing options...
DrD123 Posted January 7, 2018 Share Posted January 7, 2018 For the 2014, P0011 is described as "Intake cam position - timing over advanced or system performance, bank 1" - here's info from the service manual on why the code sets and how to diagnose/repair Link to comment Share on other sites More sharing options...
DrD123 Posted January 7, 2018 Share Posted January 7, 2018 Also - if your oil level was low, you would have a light on the dash (there is both a level indicator light and a pressure indicator light - when the oil is at the base off the dipstick, you get the yellow level light indicating (so maybe a quart low)) Link to comment Share on other sites More sharing options...
itsfrancis6 Posted January 7, 2018 Author Share Posted January 7, 2018 Thanks DrD. I'm a real novice when it comes to technical stuff like this. It does not seem like something I can diagnose or fix without more advanced equipment. Is this something I should rush to the mechanic to fix or can I drive it the next few days until I get a day off to bring it to a mechanic? Link to comment Share on other sites More sharing options...
DrD123 Posted January 8, 2018 Share Posted January 8, 2018 Well, given the low miles, I'd clear the code and drive it a bit and see if it comes back. How fresh is the battery? Low voltage can make modern cars act odd as well. The symptoms they describe don't seem in line with what you were observing (car driving fine, the only "issue" being flashing lights, then throwing a code...) so I wonder if it's not something else like an electrical gremlin... if you drive it a bit and it starts acting up (rough idle, maybe a stall) and throws the code again, then I'd look more closely. First thing the mechanic will do is run through the diagnostic procedure, so if it's not reproducible/persistent, they aren't going to be able to find it easily (if the car behaves normally for them, then that's what they will report pack) - you should still be under the 5/60 powertrain warranty though, I imagine, so maybe it's not a bad idea to at least give them a call. Link to comment Share on other sites More sharing options...
itsfrancis6 Posted January 8, 2018 Author Share Posted January 8, 2018 There hasn't been any issues since the lights turned off. The battery is the one that came with the car when we purchased it. Doesnt seem to have any issues with starting. Link to comment Share on other sites More sharing options...
FLlegacy Posted January 14, 2018 Share Posted January 14, 2018 My last 3 batteries that tested bad started the car just fine, but their were other issues, like voltage drop during cranking and random radio memory loss. Link to comment Share on other sites More sharing options...
itsfrancis6 Posted March 26, 2018 Author Share Posted March 26, 2018 I was going through some old paperwork and saw that they had extended the transmission warranty of this car for the cvt . Could this code be related to cvt issues? Link to comment Share on other sites More sharing options...
