LLimited12 Posted June 12, 2017 Share Posted June 12, 2017 My 2012 2.5i Limited has recently started stalling if it hit my brakes too hard. Not even a panic stop, just firm braking. All of the lights illuminate but after putting the car into park, it starts back up and runs perfectly fine. I have done a bit of research and found that it could be a faulty ICA Valve, faulty torque convertor, a vacuum leak (which I find highly doubtful considering everything runs and works like normal until I hit the brakes a little hard.), or the least unlikely is a faulty/overly sensitive engine immobilizer. You guys ever had this problem? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LLimited12 Posted June 12, 2017 Author Share Posted June 12, 2017 Update: went to move my car and my dashboard is lit up like a Christmas Tree. My friends 2010 Tribeca had the exact same lights on but she never found out what the problem was. She's idles fine. I don't understand. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LLimited12 Posted June 12, 2017 Author Share Posted June 12, 2017 Update: went to move my car and my dashboard is lit up like a Christmas Tree. My friends 2010 Tribeca had the exact same lights on but she never found out what the problem was. She's idles fine. I don't understand. Sent from my iPhone using Tapatalk Cruise Control is also flashing. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted June 12, 2017 Share Posted June 12, 2017 The dash lights are Subaru's way of getting your attention that your check engine light is on. Have your codes pulled and fill in your model/trim information and we can help you better. If you have a cvt this issue has been discussed a lot with torque converter failures. Link to comment Share on other sites More sharing options...
LLimited12 Posted June 12, 2017 Author Share Posted June 12, 2017 The dash lights are Subaru's way of getting your attention that your check engine light is on. Have your codes pulled and fill in your model/trim information and we can help you better. If you have a cvt this issue has been discussed a lot with torque converter failures. Codes were pulled. O2 Sensor and Mass Air Flow Sensor. Lights weren't cleared but went off while I was on my way home. It's a 2012 Legacy 2.5i Limited PZEV. 96K miles. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dgoodhue Posted June 12, 2017 Share Posted June 12, 2017 Have the spark plugs been changed? Link to comment Share on other sites More sharing options...
FLlegacy Posted June 13, 2017 Share Posted June 13, 2017 ^^^yeah plugs and cleaning the MAF might be a good bet and at this mileage a good maintenance task. Link to comment Share on other sites More sharing options...
LLimited12 Posted June 13, 2017 Author Share Posted June 13, 2017 I have been planning on ordering spark plugs for some time now. I doubt they have ever been changed. I might try to order them tomorrow. If I can get it to throw a code again, I'll be taking it to my local dealer to be fixed. An extended warranty I purchased covers literally anything under the hood that isn't routine, so I'll make use of it lol Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
acumenhokie Posted June 13, 2017 Share Posted June 13, 2017 An extended warranty I purchased covers literally anything under the hood that isn't routine, so I'll make use of it lol Changing spark plugs is routine. Link to comment Share on other sites More sharing options...
amidroc Posted August 12, 2017 Share Posted August 12, 2017 I know this is an old thread...this sound like the same issue as my 2010 2.5i with CVT. I took it to the dealer and they are replacing the torque converter. Link to comment Share on other sites More sharing options...
benleg Posted August 14, 2017 Share Posted August 14, 2017 Sounds exactly like the torque converter problem. Link to comment Share on other sites More sharing options...
LLimited12 Posted August 15, 2017 Author Share Posted August 15, 2017 I know this is an old thread...this sound like the same issue as my 2010 2.5i with CVT. I took it to the dealer and they are replacing the torque converter. She’s at the dealer for a new issue. I actually forgot to mention that to them, but I will when they call me tomorrow. Thanks for reminding me. Lol Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
nads Posted August 18, 2017 Share Posted August 18, 2017 A bad brake booster will cause stalling on braking as it becomes a vacuum leak and un-metered air enters the engine. Link to comment Share on other sites More sharing options...
carpenterltd Posted August 19, 2017 Share Posted August 19, 2017 Subaru sent out letters for this issue... Take it to the dealership. I bet you own a CVT? Link to comment Share on other sites More sharing options...
