VtspecB Posted April 21, 2009 Share Posted April 21, 2009 The right front sticks enough that after a 30 mile trip at highway speeds there was noticeable smell and some small amount of smoke when stopped to inspect it. I bled it last night with no change in the symptoms, the fluid did not look cooked or any different than normal. I then put the entire car up off of all fours and started it, put it in 1st and as expected all wheels turn except front right. Any suggestions on the next step? What else can I do to eliminate other possibilities for causes of the problem. I'm running ATE fluid, Hawk pads and SS lines. The lines appear to be intact and there was no problem bleeding it. Additionally there's only 36k on the car. As others have noted its $300+ from the stealership for a new one. I've read about replacement calipers from these guys but there is nothing specific to the GT and I'm pretty certain the calipers are GT vs. 2.5i specific due to the rotor size difference. Lastly I've also read about the rebuild kits, worth the trouble? Is it relatively easy to do? Thoughts? suggestions? Please post is up. Thanks! my vBGarage Link to comment Share on other sites More sharing options...
captainmorgan Posted April 21, 2009 Share Posted April 21, 2009 Your pads are sticking in the sliders. Pull them out, grease (they make special brake caliper grease) the sliders and reinstall. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 21, 2009 Share Posted April 21, 2009 1) Go to Autozone 2) Enquire about a reman caliper 3) Purchase reman caliper 4) Swap 5) Return your caliper for core 6) done. In my experience, a reman caliper has been $75 including a $50 core charge. Might be a little more for the Spec-B, but it's not a 4-piston alum. caliper so it shouldn't cost TOO much. Probably ~$125 incl $50 core or something. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 21, 2009 Share Posted April 21, 2009 Here, I found this link for you: http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?displayName=Brake+Caliper+-+Front&itemId=prod11143&navValue=14400852&parentId=cat10005&productId=692659&fromString=&itemIdentifier=692659_0_5913_&filterByKeyWord=&categoryNValue=&isSearchByPartNumber=&categoryDisplayName=Brakes&store=1680&skuDescription=FencoReman/BrakeCaliper-Front&fromWhere=&searchText=&_requestid=196404 $70 plus a $50 core charge. So $121, and you get $50 back when you return your stock caliper. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
VtspecB Posted April 21, 2009 Author Share Posted April 21, 2009 1) Might be a little more for the Spec-B, but it's not a 4-piston alum. caliper so it shouldn't cost TOO much. Probably ~$125 incl $50 core or something. Nothing special about the spec.b calipers, although Vimy might say differently. A remaned is certainly the easiest way to go. I'll also look at greasing the pads ... thanks capt. my vBGarage Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 21, 2009 Share Posted April 21, 2009 The link I posted above is for the LGT caliper. I can only assume that the brakes are at least similar between the LGT and the Spec B... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
VtspecB Posted April 21, 2009 Author Share Posted April 21, 2009 The vacation pics are great!04 - Front Disc Brake Assembly.pdf my vBGarage Link to comment Share on other sites More sharing options...
VtspecB Posted April 21, 2009 Author Share Posted April 21, 2009 The link I posted above is for the LGT caliper. I can only assume that the brakes are at least similar between the LGT and the Spec B... Absolutly the same ... thanks for the link! my vBGarage Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 21, 2009 Share Posted April 21, 2009 If only Autozone had reman'd rear calipers... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
tealdub Posted April 21, 2009 Share Posted April 21, 2009 When you get it done let me know which pin was sticking please. I have come to notice it is usually the lower one. Link to comment Share on other sites More sharing options...
NutBucket Posted April 21, 2009 Share Posted April 21, 2009 Huh? Why would you need a reman caliper for a sticking pin? Link to comment Share on other sites More sharing options...
tealdub Posted April 21, 2009 Share Posted April 21, 2009 not just sticking, usually stuck. replaced one on a forester the other day that was seized up. just wondered which one was sticking/hanging up. Link to comment Share on other sites More sharing options...
welby Posted April 21, 2009 Share Posted April 21, 2009 I just had a problem with my front driver's side where the pins were fine but one of the caliper pistons was frozen up. You might want to check that too. If you can't squeeze it in with a standard c-clamp then there's your problem. I had to take my caliper of and crank it in a vice to break mine loose... Link to comment Share on other sites More sharing options...
VtspecB Posted April 21, 2009 Author Share Posted April 21, 2009 Welby ... I read your post on pulling out the piston, replacing the seal and putting it back together eventhough it was kind of pitted. Did this work in the long run? Is it easy enough to do (taking appart the caliper) and putting it back together? my vBGarage Link to comment Share on other sites More sharing options...
Jester Posted April 21, 2009 Share Posted April 21, 2009 I've just experienced the same symptoms including smoke and hot metal smell when stopped. One of the 2 pistons on a front calliper was seized. Needed a G-clamp to budge it, but moves fine now. been fine since. Link to comment Share on other sites More sharing options...
VtspecB Posted April 22, 2009 Author Share Posted April 22, 2009 Went with a reman'd from a local parts store. I installed it last night, works great. I didn't even consider that in the first place because, silly me, I called the stealership asked for prices on new and reman'd and they said "oh that's a 2006, they don't make remans for them yet. $300 for a new one **stands w/ hand out**" That's what you get for listening to the dealer .... g-damn crooks! my vBGarage Link to comment Share on other sites More sharing options...
Paisan Posted April 22, 2009 Share Posted April 22, 2009 Is the car still under warranty? If so it should be covered. -mike Link to comment Share on other sites More sharing options...
welby Posted April 22, 2009 Share Posted April 22, 2009 Welby ... I read your post on pulling out the piston, replacing the seal and putting it back together eventhough it was kind of pitted. Did this work in the long run? Is it easy enough to do (taking appart the caliper) and putting it back together? It seems like it's holding up fine, but who knows for how long, lol. Every now and then I still get a slight vibration on braking, but I'm wondering if my stuck piston actually warped the rotor a little bit. I'm not going to worry about it unless it gets bad again. If it does, I'll get a rebuilt one like you did Link to comment Share on other sites More sharing options...
VtspecB Posted April 22, 2009 Author Share Posted April 22, 2009 Is the car still under warranty? If so it should be covered. -mike I just past 36k ... wouldn't have mattered anyway Kinney Subaru in Rutland, VT (trying to smear their name as much as possible) is worthless! Not only can they not diagnose and fix simple problems, but to cover their tracks they claim it is related to the non-factory parts that are installed and charge you for the estimate. Needless to say, they are not mod-friendly. Avoid them at all costs. my vBGarage Link to comment Share on other sites More sharing options...
Paisan Posted April 22, 2009 Share Posted April 22, 2009 Bummer, cause it would be covered under the 3/36k warranty. -mike Link to comment Share on other sites More sharing options...
