HeinekenSubie Posted December 1, 2015 Share Posted December 1, 2015 Hey Guys, I recently purchased a 2008 Legacy 3.0R I know they recommend 93 premium for these cars but what are your thoughts if i started using 89 or 91 moving forward? Thanks! Link to comment Share on other sites More sharing options...
quick4dr Posted December 1, 2015 Share Posted December 1, 2015 itll run but as proven many of times. running the recommend 93 will net you better mpg and performance. Link to comment Share on other sites More sharing options...
HeinekenSubie Posted December 1, 2015 Author Share Posted December 1, 2015 itll run but as proven many of times. running the recommend 93 will net you better mpg and performance. Thanks for the reply. My main concern was if it'll cause any damage to the car in the long run. Forgot to mention I currently have 60K miles on my car. Thanks, Link to comment Share on other sites More sharing options...
Slickvic Posted December 1, 2015 Share Posted December 1, 2015 Thanks for the reply. My main concern was if it'll cause any damage to the car in the long run. Forgot to mention I currently have 60K miles on my car. Thanks, Whatever the reasons you have for cheaping out usually do not justify the negative effects. Link to comment Share on other sites More sharing options...
HeinekenSubie Posted December 1, 2015 Author Share Posted December 1, 2015 Whatever the reasons you have for cheaping out usually do not justify the negative effects. ahah noted. Just trying to think of ways where I can cut cost that's all. I swear the price difference between 89 and 93 used to be around 30-40 cents/gallon. Here in Chicago its around 75-80 cents difference between 89 and 93. Link to comment Share on other sites More sharing options...
lee07 Posted December 2, 2015 Share Posted December 2, 2015 E85 Link to comment Share on other sites More sharing options...
sunny5280 Posted December 2, 2015 Share Posted December 2, 2015 E85 Seriously? How does it perform? Any noticeable side effects? Did you have to make any modifications to the car? Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 2, 2015 Share Posted December 2, 2015 Can't recall who but someone has built a flexfuel map for Subaru. Might be worth some research. Link to comment Share on other sites More sharing options...
Rhitter Posted December 2, 2015 Share Posted December 2, 2015 Can't recall who but someone has built a flexfuel map for Subaru. Might be worth some research. Delicious Tuning with Cobb Access Port. I think EcuTek might also make one. Nothing for Open source yet. Seriously? How does it perform? Any noticeable side effects? Did you have to make any modifications to the car? For our cars (2.5 turbos) you need at least larger injectors and a larger fuel pump. 30% less gas mileage. The noticeable side effect is more power . You probably don't want to do it until you have the following though: Injectors (850-1000cc talk with your tuner) Downpipe TMIC Catless uppipe (if your car came with a catted one) Money set aside for a new clutch Fuel pump I am probably missing something. Just saw you are in Denver. Cryotune is right near you and tunes a bunch of cars for E85. I think at that elevation you don't even need injectors. But talk with Cryotune. My OBXT build Link to comment Share on other sites More sharing options...
sunny5280 Posted December 2, 2015 Share Posted December 2, 2015 Thanks for the information OB2.5XT. Given all that I'm very unlikely to make modifications for this use. Thought it would be cool to try if there weren't any modifications that needed to be made. Since that's not the case it looks like it's still premium gas for me. Link to comment Share on other sites More sharing options...
apexi Posted December 2, 2015 Share Posted December 2, 2015 I'd run 91 if it's available. Link to comment Share on other sites More sharing options...
HeinekenSubie Posted December 3, 2015 Author Share Posted December 3, 2015 I'd run 91 if it's available. This is perfect. Thanks for sharing Link to comment Share on other sites More sharing options...
Jongrom Posted December 4, 2015 Share Posted December 4, 2015 I say run Avgas... Higher octane, higher boost! But really my 2c is run quality fuel (Chevron... Or Chevron)lol and go ahead and try a tank of reg and then a tank of premium and you might be surprised to see the difference in MPG, and pinging. Link to comment Share on other sites More sharing options...
98legwag Posted December 4, 2015 Share Posted December 4, 2015 I run 93 in my 3.0R. I have never put anything else in since I bought with 62,xxx and it now has 77,xxx. Link to comment Share on other sites More sharing options...
covertrussian Posted December 5, 2015 Share Posted December 5, 2015 E85 Friend of mine's 3.0R knocks really badly even with 93 gas... (IAM/DAM below .500) hence I agree on the E85 suggestion. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
PJM Posted December 5, 2015 Share Posted December 5, 2015 Wait until a BMW pulls in - and buys premium, when he leaves - go buy 1 gal of regular from the same pump- the fuel in the hose is about 1 Gal - and you will be getting the back end of his pump!! Drive 20 miles a do it again... hahah Link to comment Share on other sites More sharing options...
HeinekenSubie Posted December 6, 2015 Author Share Posted December 6, 2015 Wait until a BMW pulls in - and buys premium, when he leaves - go buy 1 gal of regular from the same pump- the fuel in the hose is about 1 Gal - and you will be getting the back end of his pump!! Drive 20 miles a do it again... hahah Lmao ahah genius! Link to comment Share on other sites More sharing options...
