Scubaboo Posted May 28, 2020 Share Posted May 28, 2020 Havent used the LGT in a month so used it today. Driver window wont go down. Fuse is good, changed it anyway, nothing. When I press the switch the engine idle lowers very slightly, like it's drawing a lot of current. I tried all the windows, the right rear stuck for a while like it usually does but started working after a few presses. Driver window still not working and been pressing it all morning in case it was slightly stuck. Also tried thumping the glass with my palm and pushing against the glass and downward while pressing, no luck. Argh. Wondering if anyone experiemced similar and what it could be? Link to comment Share on other sites More sharing options...
stewdogg Posted May 28, 2020 Share Posted May 28, 2020 Sounds like the motor is seized up. Link to comment Share on other sites More sharing options...
Scubaboo Posted May 28, 2020 Author Share Posted May 28, 2020 Yeah looks like it. Been futzing with the button all day and the window didnt even twitch. Will dive into it tomorrow and see whats up. Local dealer has the motor in stock so will see how it goes. Link to comment Share on other sites More sharing options...
creep_nu Posted May 28, 2020 Share Posted May 28, 2020 mine does that if i don't drive it for a couple weeks...window just gets hung up in the track. couple sharp taps on the window towards the top of the frame while holding the button down usually gets it unstuck. the motor isn't strong enough to break the seal on its own, so a bit of percussive maintenance helps free it up. i keep meaning to put some silicon spray on the weather stripping whenever it happens, but never do because i immediately forget when i get home. Link to comment Share on other sites More sharing options...
Scubaboo Posted May 28, 2020 Author Share Posted May 28, 2020 Will try that tomorrow, thanks! Link to comment Share on other sites More sharing options...
Alexmed2002 Posted May 28, 2020 Share Posted May 28, 2020 i keep meaning to put some silicon spray on the weather stripping whenever it happens, but never do because i immediately forget when i get home. Link to comment Share on other sites More sharing options...
Scubaboo Posted May 29, 2020 Author Share Posted May 29, 2020 Thumping the glass didnt work. Opening everything up, it looks like the motor carbon brush is almost used up and not contacting the armature. Bent the brush holder towards the armature and got the motor working, but with how worn the brush is, it wont last long. So I got a new motor/regulator at the dealer (drove there and back with the window down in the door lol) New motor/regulator is in and it's now working as it should. Link to comment Share on other sites More sharing options...
Scubaboo Posted May 29, 2020 Author Share Posted May 29, 2020 Inside the door panel Mechanism out Opening the motor You can see the brushes on the flexible springy holders New assembly from the dealer I also lubed all the window channels with silicone spray. Hope I dont have to worry about my windows for a long while. Link to comment Share on other sites More sharing options...
