Claw Posted April 23, 2021 Share Posted April 23, 2021 Has anyone attempted a DIY smoke test on their Legacy? My CEL comes on randomly and goes away at odd times (after a complete fill up, or when the tank is about to empty, sometimes when I'm on the freeway) but every time it's a P0447: P0447 - Evaporative emission control system vent control low input My stealership wants $90 to pull the code (I already know what it is, and they want to do it again) and $160 to do a smoke test which is bloody highway robbery. So my friend linked some Amazon smoke testers but I just saw the Youtube video where a guy made one from a pasta sauce jar, a soldering iron and a bike pump. I've replaced the gas cap and also I have a charcoal box I got from a junkyard that I haven't swapped in yet... but I'm wondering how accurate a DIY smoke test would be compared to taking it into the stealership... Link to comment Share on other sites More sharing options...
Max Capacity Posted April 23, 2021 Share Posted April 23, 2021 There may be a link to one in this thread in the past year or so. https://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html Ask google too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted April 25, 2021 Share Posted April 25, 2021 I bought one for around 100 bucks and called it a day, rather than try and rig something together. It works really well too, can't complain. https://www.amazon.com/gp/product/B0746SL9D6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 28, 2021 Share Posted April 28, 2021 Coming on and going off on its own leads me to believe it's an intermittent issue. I'd ohm the sensor and compare it to factory specifications. Leak tests will not tell you if a solenoid or valve is bad unless you're able command it on/off or open/closed. You can pull the valve and supply your own power and ground several times to see if it opens and seals but if the resistance (ohms) are out of spec, there's no need to go further until you have a new valve. Link to comment Share on other sites More sharing options...
Claw Posted May 10, 2021 Author Share Posted May 10, 2021 I'm not sure I understand what you're suggesting - probably best I take it to a shop. I'm more adept at mechanical work but my electrical skills need work. Link to comment Share on other sites More sharing options...
amusa Posted May 10, 2021 Share Posted May 10, 2021 (edited) Back in the old days we use to puff cigar's/hookah smoke in. Now my friend calls me to smoke the hookah for a smoke test. Since I have the lung's for it.... For a P0447, Vent Valve/Solenoid open circuit. You need to check the Fuel cap, hose and use a ohm meter for the sensor and solenoid like others previous mention. You can also check the wires and terminals if there corroded. Edited May 10, 2021 by amusa Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2021 Share Posted May 10, 2021 You might want to inspect the gas cap and maybe replace it. They are cheap. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 13, 2021 Share Posted May 13, 2021 He's already replaced the cap. There should be a 2 pin plug on the canister from the junkyard. That is the valve in question. If you have a multimeter, set it to ohms and measure the resistance across the 2 pins. I'll see if I can find the specs for max/min allowed. If you have the ability to command the valve open/closed and have a 921 or 7440 style bulb handy, bend the prongs on the bulb and insert them into the connector. While commanding the valve open or shut, the bulb should light up letting you know there is power and ground. Take it one step further and wiggle the wiring to see if the bulb cuts out indicating a broken wire. Link to comment Share on other sites More sharing options...
Claw Posted May 17, 2021 Author Share Posted May 17, 2021 I replaced the replacement camp (the replacement was from used loaner from a friend that doesn't have the P0447) with a new one from the stealership and the P0447 went away. I now have a P0031, O2 sensor heating element low voltage Link to comment Share on other sites More sharing options...
