az645 Posted April 27, 2018 Share Posted April 27, 2018 What does everyone use to keep the screen and climate controls clean and dust free that does little to minimal scratching of the surface? Link to comment Share on other sites More sharing options...
IcEWoLF Posted April 27, 2018 Share Posted April 27, 2018 I use these to clean my glasses and they work very well MagicFiber Microfiber Cleaning Cloths, 6 PACK https://www.amazon.com/dp/B0050R67U0/ref=cm_sw_r_cp_api_i_wO64Ab3X8KKD7 Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted April 28, 2018 Share Posted April 28, 2018 Just look for a screen cleaning kit. It'll have a spray and microfiber cloth. I keep them in my glovebox. Link to comment Share on other sites More sharing options...
Eugene Onegin Posted April 28, 2018 Share Posted April 28, 2018 I use a large makeup brush ( it belonged to my Mother )and that works for me . Link to comment Share on other sites More sharing options...
dr3w Posted April 28, 2018 Share Posted April 28, 2018 I use a isopropyl alcohol wipe (wound wipe, found on first aid kits) and then a microfiber towel to buff away the residue. It works on my phone, my glasses, even the STARLINK Multimedia system. Hope this helps. Link to comment Share on other sites More sharing options...
Jason07 Posted April 30, 2018 Share Posted April 30, 2018 I use a cloth that is used to clean eye glasses/phone screens since I had a surplus lying around and I recently purchased a window cleaner safe for navigation screens as well from Adam's Polishes. Only used it once so far so can't really comment on how great it is but I'm sure with appropriate amount of cleaner it wont streak. Link to comment Share on other sites More sharing options...
BradLegacy2017 Posted April 30, 2018 Share Posted April 30, 2018 Microfiber + screen cleaner or invisiglass cleaner. We also have a screen protector on ours to prevent permanent scratches. Link to comment Share on other sites More sharing options...
madmax988 Posted May 3, 2018 Share Posted May 3, 2018 I use a isopropyl alcohol wipe (wound wipe, found on first aid kits) and then a microfiber towel to buff away the residue. It works on my phone, my glasses, even the STARLINK Multimedia system. Hope this helps. I'd be real careful using alcohol on screens. It's really not the best idea and is usually specifically mentioned not to do it in instructions. Alcohol can eat away the plastics slowly, we call it "glass" but modern eyeglasses, and your multimedia screen are usually actually a very hard clear plastic. (Phone screens are actual glass, but still have the coatings to worry about). Alcohol will eventually cause hazing. Not to mention there's usually a chemical coating to reduce fingerprints showing up that will get removed, causing you to have to clean it even more often. A slightly damp microfiber cloth is probably plenty just to get normal dust off. If its really dirty you could add some mild soap or something. Link to comment Share on other sites More sharing options...
Ovcoursitsilver Posted May 4, 2018 Share Posted May 4, 2018 We also have a screen protector on ours to prevent permanent scratches. Any issues with loss of touch sensitivity with that protector? Did you just buy a big piece of protector sheet or is it made to fit? Link to comment Share on other sites More sharing options...
BradLegacy2017 Posted May 4, 2018 Share Posted May 4, 2018 Any issues with loss of touch sensitivity with that protector? Did you just buy a big piece of protector sheet or is it made to fit? It's cut to fit. No loss/impact of touch sensitivity. Cuts down on glare and fingerprints about 50% I would say. Is it 100% perfect, no....you can totally tell there is a screen protector there. The edges on mine were not cut 100% cleanly everywhere......but that being said.....for $12 I am certain this will prevent any scratches and potential damage to the radio/touch screen.....and it came as a 2 pack as well. link: https://www.amazon.com/gp/product/B01MEC1W7W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
