edgemoulic Posted August 17, 2018 Share Posted August 17, 2018 A start up on this project of mine and if you have some add-ups on this DIY Timing Belt Project please comment Thanks in Advance. Link to comment Share on other sites More sharing options...
FJuan Posted August 17, 2018 Share Posted August 17, 2018 Just to add during your process that most get upset with is the aligning of the timing marks on the belt itself. Do yourself a favor and don't worry about the timing marks on the belt, but to concentrate on the timing marks on the gears instead. Making sure they align with the marks on the block/cover. Hand rotate the motor several times making sure the all marks align back up. I've seen a few where they trusted their alignment the 1st time and when it came time to start the motor, it idle rough and stalled out. Then they had to go back and do it again. Good luck! My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Harsho1 Posted August 17, 2018 Share Posted August 17, 2018 Make sure you really check your front crank pulley while you have it off. Mine delaminated the weekend after I bought it, and chewed through the front timing cover. I went with a perrin aluminum crank pulley for about 1/2 the price of OEM and never have to worry again! Link to comment Share on other sites More sharing options...
apexi Posted August 17, 2018 Share Posted August 17, 2018 I almost didn't mention this, but why not.. be careful removing the bolts in the cover, especially the lower ones. I forget if the back of the bolts are exposed, I think they are. I'd hit them with penetrating oil to reduce the chance of the nut in the cover breaking loose. The cover is cheap, but it looks annoying to replace since you have to pull the cam gear. I'd also put anti seize on the bolts when you put them back in. https://parts.subaru.com/p/Subaru_2005_Legacy-Sedan-25L-4AT-4WD/COVER-BELT-NO2-LEFT/49226202/13575AA12A.html Link to comment Share on other sites More sharing options...
edgemoulic Posted August 18, 2018 Author Share Posted August 18, 2018 Thanks for the input Everyone, looks like nothing complicated to do except that timing marks between the blocks and timing belt. Any suggestion on putting back the crank pulley nut since I read that it should not turn counter clockwise cause might mess up with the pistons, I don’t have that special holder to use? Link to comment Share on other sites More sharing options...
apexi Posted August 18, 2018 Share Posted August 18, 2018 One more thing, do you have the toothed idler gear that sits down near the water pump? Also, I think I remember reading that the crank pulley bolt is torque to yield and it's recommended that you replace it? Obviously you probably don't have to, but I did anyway. Hopefully someone will step in and correct me if I'm wrong on that. Link to comment Share on other sites More sharing options...
edgemoulic Posted August 18, 2018 Author Share Posted August 18, 2018 Apexi I forgot to include it since I have a bunch of pictures rather than joining them altogether, but my purpose is for the other owners whose planning on this route as well it might help. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 18, 2018 Share Posted August 18, 2018 I found the marks on the belt very helpful. Timing belts always feel weird to me because i expect the taut side to actually be tight and the tensioner side to have little play. It usually ends up with the taut side having some play but more slack on the tensioned side, before pulling the pin. The second guessing before turning over the motor is not necessary with the marks on the belt. Link to comment Share on other sites More sharing options...
edgemoulic Posted September 4, 2018 Author Share Posted September 4, 2018 Just opened and it is due waiting for a big thing to happen! Link to comment Share on other sites More sharing options...
edgemoulic Posted September 4, 2018 Author Share Posted September 4, 2018 How important is the guide on this part, I opened mine and it’s not there, I wonder if my model don’t have it or they forgot to put it back. Link to comment Share on other sites More sharing options...
relative4 Posted September 4, 2018 Share Posted September 4, 2018 Only manual transmission cars have the timing belt guides. Automatic transmission cars do not. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 4, 2018 Share Posted September 4, 2018 You also have a 2.5i so yours may be different. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted September 5, 2018 Share Posted September 5, 2018 Judging by the condition of the belt, id say its never been replaced. Thats top 5 worst Ive seen that has not broken. Link to comment Share on other sites More sharing options...
edgemoulic Posted September 5, 2018 Author Share Posted September 5, 2018 Judging by the condition of the belt, id say its never been replaced. Thats top 5 worst Ive seen that has not broken. I’m trying a break test on it, still holds a lot of pounds I think the steel is the one holding it, it is a Subaru OEM Belt I notice that the Belt was installed backward, if you see the letters on that part should come off first. I think the tech installing it before is on a hurry. Link to comment Share on other sites More sharing options...
edgemoulic Posted September 5, 2018 Author Share Posted September 5, 2018 Just did the Timing Belt, I return it as is Center line is fine except the left is off a few mm but it was like that when I took it off Link to comment Share on other sites More sharing options...
edgemoulic Posted September 5, 2018 Author Share Posted September 5, 2018 This was included on the kit, I’m not sure if it will fit. Originally is 4PK845 but I got was 4PK900 a bit longer and second is 5K345 OEM and got a 5PK875 which I find same length. Link to comment Share on other sites More sharing options...
