hpcbmw Posted December 7, 2015 Share Posted December 7, 2015 I've read a bunch about the pulsing brakes and am ready to do something about it. This is my wifes car (2005 LGT sedan 80k miles), and it's almost never driven hard. I looked at the KNS package, which is about $450 for rotors and pads. Autoanything has centric rotors and posiquiet pads for $280.00. Any reason to go with the more expensive setup? I just want to get rid of the pulsing/vibration. Thanks! Link to comment Share on other sites More sharing options...
Rhitter Posted December 7, 2015 Share Posted December 7, 2015 No. The $280 setup will do what you are looking for. You might be able to have a machine shop resurface your current rotors to fix the problem. My OBXT build Link to comment Share on other sites More sharing options...
hpcbmw Posted December 8, 2015 Author Share Posted December 8, 2015 Should I replace all 4 rotors, or just the fronts? Is it pretty straightforward - remove wheels the remove the rotors? Thanks! Link to comment Share on other sites More sharing options...
quick4dr Posted December 8, 2015 Share Posted December 8, 2015 if your current pads still have life left, try rebedding them. 0-40-5 0-50-5 0-60-5 0-65-5 0-50-5 then coast and drive around without braking or coming to a complete stop. Link to comment Share on other sites More sharing options...
Rhitter Posted December 8, 2015 Share Posted December 8, 2015 if your current pads still have life left, try rebidding them. 0-40-5 0-50-5 0-60-5 0-65-5 0-50-5 then coast and drive around without braking or coming to a complete stop. That's a good point. If your wife does a lot of in town driving, it's possible the build up just needs to be burned off. I was able to do that in my Honda Fit although it was a few 80-5 stops that did it for me. Few years later and the front end shimmy (in the fit is back) and the rebedding them isn't doing anything. My OBXT build Link to comment Share on other sites More sharing options...
hpcbmw Posted December 9, 2015 Author Share Posted December 9, 2015 I did the rebedding thing a few months ago. It made some difference, but the pulsing never stopped. The next step seems to be replacing the rotors. I had the stock rotors turned a few years ago, but that didn't stop the problem either. Link to comment Share on other sites More sharing options...
tLewis7 Posted December 12, 2015 Share Posted December 12, 2015 Mike @ Infamous recommends 3M green pad and elbow grease to remove the build-up on the rotors. Link to comment Share on other sites More sharing options...
pseank Posted December 13, 2015 Share Posted December 13, 2015 On car machining or "matching" is the recommended repair. If a new rotor has more than .002 lateral runout it is only a matter of time before the problem reoccurs. A brand new rotor MUST have the runout checked to ensure that the hub and rotor combination are not creating excess runout. Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
