EatingInternet Posted January 22, 2018 Share Posted January 22, 2018 I'm about to replace my stock downpipe with an invidia unit, and I was wondering is it worth listing it on the forum? I took a lot at recent posts and couldn't find a stock downpipe for sale. The cat in sells for about $80. Opinions? Link to comment Share on other sites More sharing options...
JustCallMeNick Posted January 22, 2018 Share Posted January 22, 2018 Sell it or keep it in case you want to return the car to stock someday. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2018 Share Posted January 22, 2018 FWIW, I still have the dp's from both my cars...years later, just in case. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 22, 2018 Share Posted January 22, 2018 I basically gave it to my buddy (so I sort of sold it for labor). I have nowhere to store anything other than a relatives. So if storage was NOT tight I would have kept it. Only thing I have kept so far is the stock CV shafts and am going to re-boot them and possibly sell or keep as these aftermarket ones have very little vibration compared to most. Link to comment Share on other sites More sharing options...
relative4 Posted January 22, 2018 Share Posted January 22, 2018 If your area has emissions testing, or if there's any chance you'll move to an area with emissions testing, keep it for sure. Otherwise sell it to someone who needs it for emissions testing. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 22, 2018 Share Posted January 22, 2018 By emissions do you mean "sniffer-test" or just a 'OBD test'? Is CA the only test w/ a sniffer portion? NY just does a visual check for a cat, and as long as no CEL is thrown they do not investigate further. EDIT: I guess it makes it important, is the Invidia catted or not? If it is not catted then I would change my prior opinion... keep it. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2018 Share Posted January 22, 2018 Yep buy the catted dp. In most states it will pass the visual insp. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted January 22, 2018 Share Posted January 22, 2018 Invidia catted is up higher and can't be seen. I can't pass visual with it and have kept my stock for the once a year check. Others are in the lower section and will pass visual for some people. If you may need it for inspection and have the room, keep it. If not, I would sell it, someone will come along that wished they had kept theirs... Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2018 Share Posted January 22, 2018 Invidia catted is up higher and can't be seen. I can't pass visual with it and have kept my stock for the once a year check. Others are in the lower section and will pass visual for some people. If you may need it for inspection and have the room, keep it. If not, I would sell it, someone will come along that wished they had kept theirs... My local testing place told me they had to look for it, but they were able to find it and it was ok. Surprised your guy just didn't look harder, may be tell them its higher up the pipe next time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 22, 2018 Share Posted January 22, 2018 If an inspector told me they couldn't find it and failed it I would ask him to come out to the car w/ me; open the hood and point down to it and say "did you get your inspectors license from a cereal box?" Then I'd question him on if it's a bad thing that the cat gets warm from being so close to the engine; I am sure they would offer a water spraying system to keep it cool Link to comment Share on other sites More sharing options...
utc_pyro Posted January 22, 2018 Share Posted January 22, 2018 Invidia catted is up higher and can't be seen. I can't pass visual with it and have kept my stock for the once a year check. Others are in the lower section and will pass visual for some people. If you may need it for inspection and have the room, keep it. If not, I would sell it, someone will come along that wished they had kept theirs... They've never given me crap about mine. In reality the mirror thing is only a show in TN, ODB-II and gas cap test is all they care about. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 22, 2018 Moderators Share Posted January 22, 2018 I have no real opinion on what you *should* do, but if you decide to sell it I pay $120 for the pair of cat converters from stock downpipes. Hit me up "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Infosecdad Posted January 22, 2018 Share Posted January 22, 2018 They've never given me crap about mine. In reality the mirror thing is only a show in TN, ODB-II and gas cap test is all they care about. The regs say they are only supposed to do mirrors for <96, but they do all. I'll try harder next year. I hate the process of replacing my downpipe each year. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 22, 2018 Share Posted January 22, 2018 The regs say they are only supposed to do mirrors for <96, but they do all. I'll try harder next year. I hate the process of replacing my downpipe each year. Better than replacing the up-pipe! Having a 2005, it is good to know that 99.9% of inspectors would not know the wagon had a front up-pipe cat (meow) there anyway. Another reason I like the STi up-pipe, looks OE! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2018 Share Posted January 22, 2018 Oh yea, catted up pipe...I wonder where mine is. It's been off the car for about 7 years now. It should be in a box of parts somewhere around the basement or one of the sheds. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
EatingInternet Posted January 23, 2018 Author Share Posted January 23, 2018 Storage is limited at my place. We do have emissions testing in washington but it's just the code reader. I've already passed (and am keeping my third cat) and my tuner will patch the CEL if I get one. I've never seen them do a sniffer test here in WA, or a visual inspection for that matter. My downpipe is catless because cheap. I really doubt I'll need it, I suppose I could always grab one from the junkyard or swap on the forums for a catted if need arises down the road. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 23, 2018 Share Posted January 23, 2018 Not easy to find a good condition one at a junkyard, they usually rip them off themselves around here b/c of the cats (meow). Link to comment Share on other sites More sharing options...
utc_pyro Posted January 23, 2018 Share Posted January 23, 2018 Not easy to find a good condition one at a junkyard, they usually rip them off themselves around here b/c of the cats (meow). That's because it's actually illegal to sell used cats unless you have a way to verify it's operational. This law was meant to prevent people from buying bad ones, but probably causes a net increase in emissions due to people not fixing emissions issues on a cost basis. Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2018 Share Posted January 23, 2018 Where do you guys sell used cats? Metal recyclers? I have two catted uppipes laying around and was wondering if I can get any coin for them. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 23, 2018 Share Posted January 23, 2018 Metal recyclers, or BarManBean Any scrap metal place I believe will pay for them. Just call and ask for what they're valuing them at currently. OE cat gets more than aftermarket BTW Link to comment Share on other sites More sharing options...
relative4 Posted January 23, 2018 Share Posted January 23, 2018 You can get more for them on eBay than for scrap. Link to comment Share on other sites More sharing options...
EatingInternet Posted January 24, 2018 Author Share Posted January 24, 2018 Thanks guys. I think I'll keep my original dp just in case and next time emissions comes around if I don't need it I'll probably sell it. As for the uppipe "bye bye." Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 24, 2018 Moderators Share Posted January 24, 2018 That's because it's actually illegal to sell used cats unless you have a way to verify it's operational. This law was meant to prevent people from buying bad ones, but probably causes a net increase in emissions due to people not fixing emissions issues on a cost basis. It's illegal to sell them for reuse unless you recertify them. It's not illegal to sell them for scrap except in certain states. You can get more for them on eBay than for scrap. Sometimes. Although I also sometimes buy them on eBay for less than scrap value. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted February 11, 2021 Share Posted February 11, 2021 Where do you guys sell used cats? Metal recyclers? I have two catted uppipes laying around and was wondering if I can get any coin for them. I guess you missed my post from last Sept. I googled, https://www.google.com/search?q=catalytic+converter+recycling+near+me&rlz=1C1OKWM_enUS906US906&oq=catillytic+converter+recy&aqs=chrome.2.69i57j0i13i457j0i13l6.25504j0j15&sourceid=chrome&ie=UTF-8 I got about $1800 for two of them. You need to send them the two part numbers off the two cats in each pipe. Something like this, 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 12, 2021 Share Posted February 12, 2021 Man I sold my 2010 cat for $600. Should’ve waited lol Link to comment Share on other sites More sharing options...
