05Jdm2.0gt Posted June 3, 2018 Share Posted June 3, 2018 lowered again Sent from my LG-LS998 using Tapatalk Link to comment Share on other sites More sharing options...
stocklgt Posted June 4, 2018 Share Posted June 4, 2018 Im hoping with rolled fenders ill be able to pull off my 18x8.5 +44s on 255/35 18s. Always wanted a meaty tire, hate stretched, but now im thinking i shouldve stuck with a 235 or 245. Any thoughts as to if a roll will get it done or if i have to pull them? Trying to avoid that...I don't mind raising it up a bit, but im not that low to begin with. Link to comment Share on other sites More sharing options...
jrho Posted June 4, 2018 Share Posted June 4, 2018 Im hoping with rolled fenders ill be able to pull off my 18x8.5 +44s on 255/35 18s. Always wanted a meaty tire, hate stretched, but now im thinking i shouldve stuck with a 235 or 245. Any thoughts as to if a roll will get it done or if i have to pull them? Trying to avoid that...I don't mind raising it up a bit, but im not that low to begin with. Really depends on how low you are but I would expect you will have to at least to a slight pull in the front. Even on 235/40s on a 9.5 et38 I had to do some slight pulling in the front so I wouldn't rub. A 235 on a 8.5 would only be slightly stretched anyways Link to comment Share on other sites More sharing options...
magnusonsubie Posted June 4, 2018 Share Posted June 4, 2018 My set up is 245/35 on the same size wheel you've got and it actually rubs less now than my old 235/40 tires did due to shorter sidewalls. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
stocklgt Posted June 4, 2018 Share Posted June 4, 2018 Really depends on how low you are but I would expect you will have to at least to a slight pull in the front. Even on 235/40s on a 9.5 et38 I had to do some slight pulling in the front so I wouldn't rub. A 235 on a 8.5 would only be slightly stretched anyways howd u do the pull method? car is in for paint so id like to do it beforehand so it doesnt crack...No splash guards with the new bumper etc. so i dont have to worry about that at least. Ya, I shouldve gone with a 245 setup, but i wanted more meat. oh well...guess i need to pull after all, or maybe stick with the weak 7.5s or the 8" SSRs time being Link to comment Share on other sites More sharing options...
jrho Posted June 4, 2018 Share Posted June 4, 2018 howd u do the pull method? car is in for paint so id like to do it beforehand so it doesnt crack...No splash guards with the new bumper etc. so i dont have to worry about that at least. Ya, I shouldve gone with a 245 setup, but i wanted more meat. oh well...guess i need to pull after all, or maybe stick with the weak 7.5s or the 8" SSRs time being I personally do it with phone books and a heat gun. I know some people use a fender roller to pull their fenders but you end up getting the edges of the fender flared out which I don't really like. Just heat up the paint like you would before doing a fender roll, jack up the car, place a phone book between the tire and the fender and then lower the jack. I will usually place a couple of 2x4 pieces under the tire to have it compress and then usually will hop on the door sill a little to let it settle. Start off small and work your way up. Once you remove the phone book the fender will go back in a decent amount. Sorry if that's super confusing Link to comment Share on other sites More sharing options...
stocklgt Posted June 4, 2018 Share Posted June 4, 2018 I personally do it with phone books and a heat gun. I know some people use a fender roller to pull their fenders but you end up getting the edges of the fender flared out which I don't really like. Just heat up the paint like you would before doing a fender roll, jack up the car, place a phone book between the tire and the fender and then lower the jack. I will usually place a couple of 2x4 pieces under the tire to have it compress and then usually will hop on the door sill a little to let it settle. Start off small and work your way up. Once you remove the phone book the fender will go back in a decent amount. Sorry if that's super confusing No i get it. Just seems super shady lol. i think ill just roll for now and get 245 35s instead, too risky on fresh paint Link to comment Share on other sites More sharing options...
jrho Posted June 4, 2018 Share Posted June 4, 2018 No i get it. Just seems super shady lol. i think ill just roll for now and get 245 35s instead, too risky on fresh paint Honestly I find it the easiest way to get a consistent pull which you can't really get with a fender roller unless you're a rolling god. It's a pretty common method that I've seen used on a lot of cars but to each to their own. You could always test fit first and see if you even need to pull your fenders Link to comment Share on other sites More sharing options...
stocklgt Posted June 4, 2018 Share Posted June 4, 2018 Honestly I find it the easiest way to get a consistent pull which you can't really get with a fender roller unless you're a rolling god. It's a pretty common method that I've seen used on a lot of cars but to each to their own. You could always test fit first and see if you even need to pull your fenders yeah im gonna try to test fit soon, just waiting on the car to get out of the body shop. They are just finishing up trimming the albero bumper to fit the gigantic fmic core i have, then its going into the booth. Link to comment Share on other sites More sharing options...
magnusonsubie Posted June 5, 2018 Share Posted June 5, 2018 If it's getting painted give the shop a call and ask if they can roll your fenders for you. Do it before paint so that any cracking of the paint isn't even a possibility. That will be what I do when I put my facelift front end on. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
stocklgt Posted June 5, 2018 Share Posted June 5, 2018 If it's getting painted give the shop a call and ask if they can roll your fenders for you. Do it before paint so that any cracking of the paint isn't even a possibility. That will be what I do when I put my facelift front end on. yeah they are getting rolled by them yesterday or today...gonna hold off on pulling though Link to comment Share on other sites More sharing options...
rchayes21 Posted June 7, 2018 Share Posted June 7, 2018 NashvilleLegacy4 (1 of 1) by Chas Hayes, on Flickr Link to comment Share on other sites More sharing options...
MPacMan15 Posted June 9, 2018 Share Posted June 9, 2018 more NT03 pics Sent from my SAMSUNG-SM-G935A using Tapatalk 1 Link to comment Share on other sites More sharing options...
Shipman Posted June 10, 2018 Share Posted June 10, 2018 Keep. Them. Comin. Link to comment Share on other sites More sharing options...
Code Posted June 10, 2018 Share Posted June 10, 2018 PacMan Nice look with the bright(ish) wheels and the chrome strip on your skirts. Your car looks great. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
stocklgt Posted June 10, 2018 Share Posted June 10, 2018 I'd murder for some NT03s in SBC. Id trade my weds any day of the week for them, so sick Link to comment Share on other sites More sharing options...
JohnnyWas Posted June 15, 2018 Share Posted June 15, 2018 http://i64.tinypic.com/5xo1s7.jpg Really need to detail this thing. Also really need to install the pile of parts laying in my shop. ¯\_(ツ)_/¯ Link to comment Share on other sites More sharing options...
Minty762 Posted June 15, 2018 Share Posted June 15, 2018 Uhg those Works are my dreams wheels One day... Link to comment Share on other sites More sharing options...
RobH Posted June 24, 2018 Share Posted June 24, 2018 Really like the black and gold combo! Keep em coming! Link to comment Share on other sites More sharing options...
SBT Posted June 25, 2018 Author Share Posted June 25, 2018 Like the whole perspective, but the tires look like rubber bands by comparison. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
JohnnyWas Posted July 23, 2018 Share Posted July 23, 2018 http://i63.tinypic.com/5jxj0o.jpg New JDM BP9 front end sits a bit lower than the old stock body did, but luckily the OEM STi front lip has a forgiving rubber skirt to it. Link to comment Share on other sites More sharing options...
Lgt005 Posted July 27, 2018 Share Posted July 27, 2018 (edited) I’ll add to this 18x9.5 NTO3’s 265/35/18’s Rolled and pulled front and rear Feal 441 coilovers w/ 8k swift springs Kta 124 rear control arms 24mm sway bars front and rear w/ kartboy end links What spring rates are you guys running? I think I need something stiffer. I currently rub a little more than I would like and want to go a little lower (raised my car a little after the first picture because it rubbed to much on bumps and turns) Edited July 27, 2018 by Lgt005 Link to comment Share on other sites More sharing options...
magnusonsubie Posted August 14, 2018 Share Posted August 14, 2018 Potentially buying some Mag Blue TE37's in 18x9.5 +38. Wont have the chance to put them on till I get off this ship sometime in the winter or next spring. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
stocklgt Posted August 14, 2018 Share Posted August 14, 2018 I dont know if I would classify this as "low" but it is a nice stance. Might lower the front another 1/4" or so to match the rear, right now its a bit lower in the rear. I still have space and no rub in the front, the rear rubs over larger bumps. Didn't want to give up the fatter tires, and NY roads aren't low friendly. Link to comment Share on other sites More sharing options...
JohnnyWas Posted August 14, 2018 Share Posted August 14, 2018 ...and NY roads aren't low friendly. Ain't that the truth! *looks at my own car, shakes head* Link to comment Share on other sites More sharing options...
