our remote entry clickers are waterproof!
I didn't realize that! I may have inadvertently put mine through the washing machine - noticed when I heard it clunking in the dryer - pulled it out and it still worked, so I figured I should take it apart and dry it out - the module where the electronics live is protected with a silicone gasket - I didn't realize that! It was bone dry inside! (I guess if you have changed the battery in yours you would know that, but after over 7 years, mine still works just fine...)
well it is not water proof but it is water resistant as there is a rubber part that goes over the circuit board that seals it into the back half of the case and provides resistance to the buttons when pressed... most key fobs are this way by design...even my old 2002 CL type S had this type of setup...
