M.mikes13 Posted December 30, 2017 Share Posted December 30, 2017 Looking into installing a dash cam, most likely a Thinkware. Anyone install on an '18? Initial concern is placement for the dash cam because of ES and rearview mirror sensor/camera. Thoughts? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 30, 2017 Share Posted December 30, 2017 mine is just to the left of my mirror. I use a a119 with gps mount. if you have eyesight, keep it away from the front facing cameras https://smile.amazon.com/gp/product/B01IEQUABA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 very compact and unobtrusive.. Link to comment Share on other sites More sharing options...
leolfds Posted December 30, 2017 Share Posted December 30, 2017 Looking into installing a dash cam, most likely a Thinkware. Anyone install on an '18? Initial concern is placement for the dash cam because of ES and rearview mirror sensor/camera. Thoughts? There used to be an area around the rearview mirror where folks used mounted their dash cameras and ez-pass to. (it is the area in between the red trapezoids in the picture below) but you cannot mount there anymore because of the high bean sensor in the newer models. Now anything being mounted to the windshield needs to be outside of the grey areas as noted on the owner manual. Link to comment Share on other sites More sharing options...
M.mikes13 Posted December 30, 2017 Author Share Posted December 30, 2017 I do remember seeing that when I browsed the user manual Leo. Hmm, I wonder if there is an issue mounting a Thinkware dashcam above the passenger side?! Maybe I'll have to contact a rep... Link to comment Share on other sites More sharing options...
leolfds Posted December 30, 2017 Share Posted December 30, 2017 Shouldn't be a problem at all mounting on the passenger side. Just make sure the camera retains the field of view for being slightly off centered so you are not cutting the image off on the driver's side. Link to comment Share on other sites More sharing options...
PhilT Posted December 31, 2017 Share Posted December 31, 2017 Make a temporary installation to try it, then you'll know. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
tornichoe Posted December 31, 2017 Share Posted December 31, 2017 I have mine installed off-center on the drivers side and I don't notice much of a loss in field of view. I've posted pics on one of the install threads if you want to search for it. I have the thinkware 750. just keep in mind that all the wires come out on the right side of the unit, so if you do install it on the passenger side, you'll need to run the cables over to the drivers side for power from across ES or from the other side and through the dash. I wasn't comfortable having cables going across the trim in front of the ES cameras (though folks the pulled that trim out say there is plenty of room), so I chose to leave it on the driver's side. Link to comment Share on other sites More sharing options...
leolfds Posted December 31, 2017 Share Posted December 31, 2017 @M.mikes13. there is your answer above. Thanks for the information @tornichoe. Link to comment Share on other sites More sharing options...
rec630 Posted January 1, 2018 Share Posted January 1, 2018 There used to be an area around the rearview mirror where folks used mounted their dash cameras and ez-pass to. (it is the area in between the red trapezoids in the picture below) but you cannot mount there anymore because of the high bean sensor in the newer models. Now anything being mounted to the windshield needs to be outside of the grey areas as noted on the owner manual. Ah, that explains why I didnt see the section for mounting in the older open area when reviewing. I was trying to figure if my tollway ez-pass was going to interfere placed under the rearview mirror and the salesguys at dealership said they had no problem, but they drove an older model. Link to comment Share on other sites More sharing options...
XT-sub Posted January 2, 2018 Share Posted January 2, 2018 ... but you cannot mount there anymore because of the high bean sensor in the newer models. Now anything being mounted to the windshield needs to be outside of the grey areas as noted on the owner manual. Because of this it can be mounted on the driver’s side of the windscreen beside the A pillar, but needs to have a wedge made to fit between the camera & the windscreen to correct the slight sideways angle of the camera due to the curve of the windscreen. This works fine on the RHD cars, but on the LHD cars make sure the micro SD card can be easily removed. If fitted in a similar location on the passenger side, the windscreen won’t be cleaned by the windscreen wipers when it is raining. This isn’t as good as being in the middle of the windscreen but we don’t have many options. Link to comment Share on other sites More sharing options...
CTUShao Posted January 4, 2018 Share Posted January 4, 2018 If you get a Blackvue instead, there's Blendmount so you can attach it to the mirror stalk. Link to comment Share on other sites More sharing options...
Ovcoursitsilver Posted January 4, 2018 Share Posted January 4, 2018 I'm assuming all of these prohibitions are because of EyeSight but since my '17 does not have ES I can mount the camera near the rear view mirror. I'm not sure if I have the high beam control but I'm thinking as long as the front of the mirror is not obstructed there should be no problem. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 5, 2018 Share Posted January 5, 2018 just a note on installation you can hard wire it: buy a hard wire kit and do it a. switched power - locate a empty fuse slot that is switched on with ignition and tap that b. constant power - locate a empty fuse slot that is hot all the time and tap that - this option *may kill your battery if the car sits for more than a day or two. it will also MURDER your SD Card in short order as it is writing to it 24 hours a day 7 days a week 365 days a year. 1080p footage will over write a 64GB card every 2-3 days if you want to use the power port in the center console - there is more than enough room to slide the wire up into headliner and then down the driver side a pillar without taking anything apart. next run wire between door gasket and dash and then under the knee bolster over to the center console. I tucked mine into the plastic that covers the top edge of the carpet and put the 12V adapter in the port under the arm rest. going on 2 years and no issues. no exposed wires to be seen Link to comment Share on other sites More sharing options...
nelshum Posted January 9, 2018 Share Posted January 9, 2018 If you get a Blackvue instead, there's Blendmount so you can attach it to the mirror stalk. Has anyone tried the blend mount? How well does it work and does it interfere with the eyesight at all? Link to comment Share on other sites More sharing options...
securityguy Posted January 9, 2018 Share Posted January 9, 2018 I have the BlendMount for my radar detector...very well made product and fits perfectly...just way more pricey than it should be. Link to comment Share on other sites More sharing options...
nelshum Posted January 10, 2018 Share Posted January 10, 2018 I have the BlendMount for my radar detector...very well made product and fits perfectly...just way more pricey than it should be. Thank you. I ordered one and hope it works well Link to comment Share on other sites More sharing options...
