havanahjoe Posted February 22, 2013 Share Posted February 22, 2013 Hey guys, I recently noticed a rattle/noise coming from my front driver side when going over irregular parts of the road. I had my oil change guys take a look when they had the car up and they said they didn't see anything obviously wrong (they didn't really go into much detail when troubleshooting). The car has 77k miles and I'm wondering if I could have a bad/blown strut. What's the expected life of the Bilstein's? What else should I check? Thanks! Link to comment Share on other sites More sharing options...
iggybdawg Posted February 22, 2013 Share Posted February 22, 2013 check the swaybar endlink with the car on the ground, it can feel tight while on the lift, but be loose while the suspension is compressed. Link to comment Share on other sites More sharing options...
iggybdawg Posted February 22, 2013 Share Posted February 22, 2013 also check the control arm bushings. Link to comment Share on other sites More sharing options...
havanahjoe Posted February 23, 2013 Author Share Posted February 23, 2013 Thanks! I'll check those out Link to comment Share on other sites More sharing options...
havanahjoe Posted March 2, 2013 Author Share Posted March 2, 2013 I spent some time with the front driver tire off trying to figure out where the rattle was coming from. I couldn't find anything there so I put everything back and popped the hood to look at the bolts on the chassis. I finally found the culprit. It was the middle bolt nut, it was loose. I tightened it and had to give it several turns. Took the car out for a quick spin and the rattle is gone. Now, when I had my springs installed, jsalicru marked all bolts in my suspension, and now the marks on this nut and bolt no longer align. What does this nut do? Should I be careful about how much torque I apply to it? Do I need to look at other alignment things? I don't know what this part of the suspension is called Is this the top hat bolt? Link to comment Share on other sites More sharing options...
havanahjoe Posted March 21, 2013 Author Share Posted March 21, 2013 Well, my rattle is back! I haven't looked under the hood but I bet the nut is loose again. Why would this happen? I tightened it the last time. Is something causing it to get loose? Link to comment Share on other sites More sharing options...
The Woo Posted March 23, 2013 Share Posted March 23, 2013 Some blue Loctite maybe? Link to comment Share on other sites More sharing options...
farberio Posted March 24, 2013 Share Posted March 24, 2013 That nut holds the topper for the strut/spring combo. It should not be moving about. I probably won't be able to torque it correctly when its in the car though because the strut tube spins. Link to comment Share on other sites More sharing options...
havanahjoe Posted March 24, 2013 Author Share Posted March 24, 2013 That nut holds the topper for the strut/spring combo. It should not be moving about. I probably won't be able to torque it correctly when its in the car though because the strut tube spins. That's what I'm worried about. The first time it got loose I just tightened it, but for it to do it again in less than a month (about 1200 miles) makes me thing there's something else wrong. Also, does this affect my alignment at all? I could try loctite but I don't know if that was used in the first place? Link to comment Share on other sites More sharing options...
farberio Posted March 24, 2013 Share Posted March 24, 2013 I don't believe it will affect your alignment but it sure could cause the rattle. I looked at my own shocks and you should be able to tighten it correctly using some sort of spark plug socket, a wrench, and an allen key to hold the strut tube. Look at this pic and you should get the idea. http://c.shld.net/rpx/i/s/i/spin/image/spin_prod_210995301?hei=315&wid=315&op_sharpen=1&resMode=sharp&op_usm=0.9,0.5,0,0 Link to comment Share on other sites More sharing options...
havanahjoe Posted March 24, 2013 Author Share Posted March 24, 2013 Oh good. I don't think I felt the strut tube moving, but it might be moving and that's why I didn't get it very tight last time. I shall give this a try. Thanks! Link to comment Share on other sites More sharing options...
farberio Posted March 24, 2013 Share Posted March 24, 2013 I should point out that I have no idea if that nut is an 18, its just an example pic only. Link to comment Share on other sites More sharing options...
Eric Posted March 24, 2013 Share Posted March 24, 2013 **Correction: it is 17mm. Thanks, farberio. I think it is a 19mm. If your Allen key is not long enough to pass-thru a spark plug socket, you can buy deep offset wrenches at a place like sears - they sell these individually, and I paid something like $15: http://www.sears.com/craftsman-10-pc-full-polish-deep-offset-wrench-set/p-00987641000P Here is another thread about this that might be helpful: http://legacygt.com/forums/showthread.php/elusive-front-end-clunk-185083.html Link to comment Share on other sites More sharing options...
farberio Posted March 24, 2013 Share Posted March 24, 2013 ^ might be hard to hit the correct tq spec with those. With the socket you can get a crows foot on it. I actually just took apart my donor shocks and it was a 17. Link to comment Share on other sites More sharing options...
Eric Posted March 24, 2013 Share Posted March 24, 2013 Quite right, farberio - it is 17mm. I just checked mine. A funny thing is, this is a different set of shocks from my last one that had been loose, and I never checked these bolts as I have never had any clunking. And what do you know - one was loose! For now I will try what I did last time using this offset wrench and an Allen key. However, you are correct that it is difficult to torque it correctly. What is a crow's foot? Maybe that would help What I was wondering was if there was some sort of Allen key on a socket that I could hold with a torque wrench while turning the strut nut. Would this even trigger the torque wrench? Something like this: http://public.fotki.com/martt/audi_tt/mods/bushings/bushing042.html#media Eric Link to comment Share on other sites More sharing options...
Throttlejockey Posted March 24, 2013 Share Posted March 24, 2013 I've been having the clunking from the driver side and checked mine and the nut was loose. I ground a few flats on a 17mm socket and used a crescent wrench on it. The shaft really didn't even spin. I used blue loc-tite also. Checked right side and it was tight. Weird because these have never been touched, as I bought the car new. Now it has 66K. Link to comment Share on other sites More sharing options...
farberio Posted March 24, 2013 Share Posted March 24, 2013 I think that could work, but that looks like an expensive specialty tool. Crows foot: http://www.teng.co.uk/images/products/large/Crows%20foot%20wrench_l.jpg Link to comment Share on other sites More sharing options...
scoobycoupe Posted March 27, 2013 Share Posted March 27, 2013 a few quick blips with an impact gun will always do the trick too Link to comment Share on other sites More sharing options...
