Mr_Palladium Posted August 2, 2012 Share Posted August 2, 2012 Any problem changing from the OEM 16x6.5 +48 with 205/60/16 tire to the OEM Gt wheels 18x7.5 +55 with a 215 or 225/45/18? I've used the fitmywheels calculator to see the difference in size but I want to make sure there is no rubbing in the wheel wheels or against the struts due to the width and offset increase. Also, what do you recommend for basic daily driving? 215 or 225 width... Link to comment Share on other sites More sharing options...
Magic Marker Posted August 2, 2012 Share Posted August 2, 2012 I'm pretty sure you'll be fine if you go with stock LGT specs. You'd only encounter rubbing if you really dropped her. At stock height I wouldn't worry. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
Mr_Palladium Posted August 3, 2012 Author Share Posted August 3, 2012 I hope so because the rims are on the way...planning on keeping stock height Link to comment Share on other sites More sharing options...
