Jolbaru_LGT Posted December 2, 2020 Share Posted December 2, 2020 I'm wondering if there's a fix for these sagging lines? They were originally spaced out fine, but the top one is sagging onto the bottom one. Is there a spacer bracket they make or any way to fix it? Thanks in advance... Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted December 2, 2020 Share Posted December 2, 2020 If I remember correctly there should be a spacer bracket there 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted December 3, 2020 Author Share Posted December 3, 2020 what is that? Part of the air conditioning? Or?.... A part number or link for a spacer would help. Link to comment Share on other sites More sharing options...
DaveWaters Posted December 3, 2020 Share Posted December 3, 2020 Fuel lines. Have you taken off the engine cover? You’ll find they’re bracketed to the intake manifold. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2020 Share Posted December 3, 2020 Here are mine from April 2012, in checking, this was the first picture I took before pulling the engine. I took over 80 photos. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted December 4, 2020 Author Share Posted December 4, 2020 Fuel lines. Have you taken off the engine cover? You’ll find they’re bracketed to the intake manifold. Yeah I have taken the cover off many times, guess I never paid attention to where they connect or what they are. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted December 6, 2020 Author Share Posted December 6, 2020 So there’s no fix, and it’s not hurting anything? Link to comment Share on other sites More sharing options...
DaveWaters Posted December 6, 2020 Share Posted December 6, 2020 Nope. Looks normal to me. Link to comment Share on other sites More sharing options...
boxkita Posted December 6, 2020 Share Posted December 6, 2020 replacement of the the lines is the fix? Its rubber and holds fuel in the engine bay. Rubber doesn't last forever. That said, it's not something ppl replace much. Ask the high mileage owners? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2020 Share Posted December 6, 2020 Yep, my wagon still has the same ones it came with. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pleides Posted December 7, 2020 Share Posted December 7, 2020 Mine were fine before engine out and I believe those are still on the car at 215K. Link to comment Share on other sites More sharing options...
boxkita Posted December 7, 2020 Share Posted December 7, 2020 confused where you think it's sagging? on the connection side or back by the bulkhead? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Marvick08GT Posted December 9, 2020 Share Posted December 9, 2020 Must be OCD like me... Just grab the metal line and bend it upwards a bit until it is straight like the rest. Doesnt hurt anything, just bugged the hell out of me until I "fixed" it. GL! Boxkita, he is referring to where the line attaches by the IM, I am pretty sure people lean on it while working on the car and bend it down slightly. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted January 6, 2021 Author Share Posted January 6, 2021 Must be OCD like me... Just grab the metal line and bend it upwards a bit until it is straight like the rest. Doesnt hurt anything, just bugged the hell out of me until I "fixed" it. GL! Boxkita, he is referring to where the line attaches by the IM, I am pretty sure people lean on it while working on the car and bend it down slightly. I did try and bend it up, I think it just weakened it. So it sagged back down Link to comment Share on other sites More sharing options...
