iNVAR Posted September 3, 2017 Share Posted September 3, 2017 So... anyone know where to get a replacement for the stock spoiler's red brake light reflector/housing? The right side of mine is cracked and coming loose. I'd like to think that I can buy this piece separate, but my Googling hasn't yield any results. I think I might be able to repair it if I remove and use crazy glue or hot glue or something else, but I'd like to just replace it if possible. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted September 3, 2017 Share Posted September 3, 2017 I'm sure you Know that most dealers have on-lines parts catalogs where you can buy OEM at a discount. Or stop by a body shop and see if they can get one or tell you whereto go...to get one. Oh, If you ask auto parts stores, some have a catalog for body parts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iNVAR Posted September 3, 2017 Author Share Posted September 3, 2017 https://www.subarupartsdepot.com/parts/2005/SUBARU/Legacy/GT%20Limited?siteid=215079&vehicleid=184583&diagram=7523850&diagramCallOut=4 Part #4. Says it's sold with spoiler assembly only ugh... Link to comment Share on other sites More sharing options...
iNVAR Posted September 3, 2017 Author Share Posted September 3, 2017 Also opposed forces doesn't list it at all Link to comment Share on other sites More sharing options...
amm203 Posted September 3, 2017 Share Posted September 3, 2017 One of these might work? https://www.spoilerlights.com/sl-category/subaru/legacy/2003-2006-legacy/ Edit: The two-tab design (last one) looks the closest. I would measure your existing and compare to their measurements. Edit 2: Found this as well... http://www.subarupartsandaccessories.com/a/Subaru_2005_Legacy/__6026754/LAMP-HIGH-MOUNT-STOP-LAMP/B13-847-02.html Link to comment Share on other sites More sharing options...
iNVAR Posted September 4, 2017 Author Share Posted September 4, 2017 $74.73 damn, that's expensive... Thanks Link to comment Share on other sites More sharing options...
amm203 Posted September 5, 2017 Share Posted September 5, 2017 Subaru junk yard might yield a donor spoiler you can snag it from, too Link to comment Share on other sites More sharing options...
