SnowBound BP5 Posted June 4, 2015 Share Posted June 4, 2015 Hi guys, I'm planning to install Bilstein shocks + JDM STi pink springs on my 2005 BP wagon. I have 18x8 wheels with either +48 or +50 offset. Taking the mandatory lift from those new JDM tophats into consideration, would this new setup require me to roll my fenders? Link to comment Share on other sites More sharing options...
Drift Motion Posted June 4, 2015 Share Posted June 4, 2015 your tire size has a lot to do with it too Link to comment Share on other sites More sharing options...
SnowBound BP5 Posted June 5, 2015 Author Share Posted June 5, 2015 your tire size has a lot to do with it too Oops sorry, I totally forgot to put that in my post! I plan on using 235/40 18 tires. Link to comment Share on other sites More sharing options...
grimbeaver Posted June 5, 2015 Share Posted June 5, 2015 No you don't. I'm running 18x8 +43 with the same size tires in addition to offset LCA bushings and I am ok. Link to comment Share on other sites More sharing options...
SnowBound BP5 Posted June 7, 2015 Author Share Posted June 7, 2015 No you don't. I'm running 18x8 +43 with the same size tires in addition to offset LCA bushings and I am ok. Thanks for the info. So I assume you also have your wagon lowered w/ Bilstein shocks and STi springs? Link to comment Share on other sites More sharing options...
grimbeaver Posted June 9, 2015 Share Posted June 9, 2015 I used to be on Ohlins & iONs with the same wheel/tire setup, and the Ohlins sat lower than the Bilstein shocks I had before, so I don't see it being an issue. You just need to make the most out of your camber bolts up front. And if you haven't already, remove the rubber stripping around the rear fenders. Link to comment Share on other sites More sharing options...
whitetiger Posted June 9, 2015 Share Posted June 9, 2015 no roll needed. Link to comment Share on other sites More sharing options...
SnowBound BP5 Posted June 10, 2015 Author Share Posted June 10, 2015 I used to be on Ohlins & iONs with the same wheel/tire setup, and the Ohlins sat lower than the Bilstein shocks I had before, so I don't see it being an issue. You just need to make the most out of your camber bolts up front. And if you haven't already, remove the rubber stripping around the rear fenders. Ohlins are $$! I've always wondered if rust would form more easily if I removed those rubber stripping on my rear. No problem for you? Link to comment Share on other sites More sharing options...
whitetiger Posted June 10, 2015 Share Posted June 10, 2015 ^no worries. pull em off. Link to comment Share on other sites More sharing options...
grimbeaver Posted June 10, 2015 Share Posted June 10, 2015 2nd hand pricing but still well worth the money! and yes, no worries with rust, just get rid of it! Link to comment Share on other sites More sharing options...
