apexi Posted April 5, 2014 Share Posted April 5, 2014 (edited) So off and on for some time now, I've had a squeaking sound (think squeaky bed mattress) coming from the rear driver side wheel when I get in and out of my car. The squeak only happens when the emergency brake is on, so I'm thinking that I might need to lube a part of the e-brake drum hardware, or replace a spring in there. I don't anything about drum brake setups, so any input is appreciated. I should also mention when the problem first started happening awhile ago, I thought it was a rear sway bar bushing, but I lubed that and I didn't help. I'm confident it's something with the e-brake, but which part I'm not sure. *I tried to go record a sound clip just now, and of course the car didn't make any noise at all. It seems like it only happens under certain conditions, maybe influenced by the weather. I don't know, I'm thinkin I might just have to live with it like I have been. Edited April 5, 2014 by apexi Link to comment Share on other sites More sharing options...
DoctorLGT Posted May 7, 2014 Share Posted May 7, 2014 Hey. Was just curious if you had figured out what was the cause of this issue? Link to comment Share on other sites More sharing options...
apexi Posted July 21, 2014 Author Share Posted July 21, 2014 (edited) I think I might have figured it out.. Last night I decided to partially take apart my parking brake and inspect it. I know very little about parking brakes and drum brakes, so I kinda winged it last night. But after doing a little reading online today, it looks like what I did was a good thing. The subaru factory service manual says you are supposed to lubricate a few parts of the parking brake assembly, as shown in the attached image. I noticed that on my car, 6 of the contact points had no lube at all, and actually had a little rust on them. So I decided to apply brake lubricant to them, and hope for the best. I didn't lube any other parts of the parking brake since it looked like you probably had to disassemble the parking brake assembly to properly lubricate them, and I didn't want to use a spray lube/grease on them just yet. So to summarize what I did.. -Left parking brake off -Pulled rear wheel off -removed rear driver side brake caliper -remove brake rotor (I had to adjust parking brake since rotor was getting stuck on parking brake shoes, even with parking brake off) -removed two shoe hold down pins with flathead screwdriver, circled in green in second attached image. This allows you to lift the parking brake shoes up a little bit so that you can access the contact points you need to lube. -cleaned 6 contact points with brake cleaner -lubed 6 contact points with brake lubricant -reinstall shoe hold down pins and springs, put rotor and caliper back on, adjust parking brake back to where it was, and if you worry a lot like me, find a hill and make sure the parking brake holds and is adjusted properly. And that's it. I'll update this in a few days or weeks depending on whether the noise comes back or not. Edited July 21, 2014 by apexi Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 4, 2020 Share Posted August 4, 2020 So, did that fix it? I have the same problem. But I’m hesitant to take it all apart, again. Shoes are a pain.. if I could get away with a spray lube without undoing everything, that would be ideal. If anyone has an opinion, I’d appreciate it. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 4, 2020 Share Posted August 4, 2020 apexi is still an active member, PM him. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 4, 2020 Share Posted August 4, 2020 apexi is still an active member, PM him. For some reason I can't send private messages. I'll write something send it, and I won't get a receipt in the "sent" folder. I have an iMac, and I've tried both Safari and Chrome. Link to comment Share on other sites More sharing options...
Infosecdad Posted August 4, 2020 Share Posted August 4, 2020 You have to enable the setting to keep a copy in sent, it’s not in by default if I remember correctly. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 4, 2020 Share Posted August 4, 2020 You have to enable the setting to keep a copy in sent, it’s not in by default if I remember correctly. LOL, thanks. I think I've got it now. Link to comment Share on other sites More sharing options...
