KarlB Posted August 14, 2020 Share Posted August 14, 2020 Hey team, I have just got a TS wagon and noticed the driving lights are not working. Not getting any power at the plug at the lights I have checked the fuses which are all ok. I came across a thread about a resistor on the right hand side but can't find anything on either side. Pulled the panels down underneath and had a search under there and nothing to be found. Any pointers? Thanks Karl Link to comment Share on other sites More sharing options...
DrD123 Posted August 14, 2020 Share Posted August 14, 2020 If the fuses are ok, next thing I would check would be the relay (assuming you mean either foglights or headlights, both will have relays associated with them) Link to comment Share on other sites More sharing options...
KarlB Posted August 15, 2020 Author Share Posted August 15, 2020 If the fuses are ok, next thing I would check would be the relay (assuming you mean either foglights or headlights, both will have relays associated with them) Thanks for that. Ill have to try and locate the relay for that. I can locate the headlight ones. but nothing is showing me which ones what on the side of the fuse box in the cabin. Link to comment Share on other sites More sharing options...
Brunzo Posted August 21, 2020 Share Posted August 21, 2020 DRL relay is in the box under the hood. Link to comment Share on other sites More sharing options...
