03LegacyLE Posted March 13, 2021 Share Posted March 13, 2021 (edited) After going back and forth, I've decided to sell my unicorn: 2005 Subaru Legacy GT Wagon Limited with 5 speed manual. Details: Year, Make and Model: 2005 Subaru Legacy GT Wagon LTD Color: OBP (Black) Miles: 135,xxx Transmission: 5MT Title: Clear - no accidents Lien: No liens Location: Charlottesville VA VIN: 4S3BP676056321266 Price $10500 History / Why am I selling: I purchased this extremely well loved car from the second owner who picked it up in Florida with 10k. He poured a lot of love, money and time into getting the car exactly how he wanted it. Eventually he wasn't driving it enough to justify it at 109k and I picked it up. The car has been truly outstanding is the nicest car i've ever had the pleasure of owning, everything works and works well. I've been EXTREMELY gentle in my ownership and so was the previous owner. In fact the first thing I did was upon getting it was to detune the car to run a more conservative 91 octane map even though I am running 93 Shell. Always. This car has never been driven hard, redlined, etc. It was my daily and trip car before the pandemic and hasn't been driven as much as i'd like since. The ONLY reason i'm selling it is that I inherited a beautiful LS400 after my brother passed and that makes 4 cars...and I work from home. It simply isn't getting driven enough and I'd rather it go to a good home. The car starts immediately and the engine makes zero noise and doesn't burn any oil. The Fluidampr really makes the engine smooth too. Power is smooth and instant and highway passing is impressive in 5th from 50-70mph. The suspension is an outstanding compromise between being sporty and luxury. It's very comfortable and quiet yet it handles well. The stock exhaust and intake keep the care very stealthy and mature. This isn't a boy racer and I hope the next owner respects it as much as we clearly have. Below is a combination of the original owners AD and some of the work i've done as well. Good: - Maintained by a well respected Subaru dealer and then 3 well respected independent shops. When anything needs to be done, it has been done. - No outstanding issues - Synthetic oil every 4k miles (usually 3k) or 6 months - Nearly new Michelin tires - Garaged or covered parking always - Interior is in very good condition - Apple Car Play/Android Auto - Never been smoked in. - AndrewTech inspect the turbo for play in the spring and they said it was good Less Good: Car has some underbody rust but everything has been treated extensively. Passenger side rear fender has a small bumble in the trouble spot but has also been treated. Paint could use a professional detail, small dent/scratch in the roof from a limb. Remote start solenoid occasionally clicks in the dash and appears to have a small battery drain effect, I keep the car on a tender. Recent power steering pump may need to be bleed again, steering can be slightly uneven. Modifications: - BBS RGR 18x8 (forged) wheels diamond black finish w/ Michelin Pilot 4S 225/45/18 - OEM wheels with Bridgestone LM-32 205-50-17 (winter) - iON Performance springs - Koni inserts - 1/2" rear spring spacers - JDM rear sway - Cobb short shifter & bushings - Thule cross bars - JDM double DIN adapter w/ Sony AX100 - Includes uninstalled rearview camera - JL Stealthbox with 10W6v2 (highend) - DLS A7 amp w/ remote sub controller (highend) - Pioneer mids with Rainbow tweeters in front with dynamat (highend) - Valentine One remote display in ashtray, wire above rear view - Remote start (installed correctly with transmission sensor) - HIR high beam bulbs - Weathertech and OEM floor mats front and rear - OEM hatch mat - Cobb cated downpipe (replaced when OEM rusted through) 2015 - Cobb AP 2015 - Invidia catless uppipe 2012 - Removed banjo filters, installed IP&T upgraded oil lines w/filter 2012 - Electronic boost gage in factory cubby Major History - Purchased Nov 26, 2006 with 10,223 miles from Fort Myers Jaguar, FL Maintenance 2006 - 2011: Flemington Subaru, Flemington NJ Maintenance 2011 - 2015: AZP Installs Kennleworth NJ - 2011 - Lower control arm bushings* - 2012 - Radiator, Valve cover gaskets, Replaced 1 RGR wheel after hitting 2" exposed manhole cover. Wheel from TireRack. Painted to Match by Wheel Collision Center Bath, PA 2012 - 2103 - OEM Clutch & OEM single mass flywheel (80k) - 2014 - Passenger front axle + CV boot 2014 (93k), 90k service + timing belt & water pump (94k), Airbag recall (94k) - 2015 - Pads and rotors (101k), Diff and trans fluid (103k), Bosch Battery (103k) Maintenance 2015 - current : AndrewTech Automotive, Gathersburg MD - 2016 - Diff & trans fluid (103k) - 2018 - Replaced fuel pump assembly (108k), Removed rear hitch, Replaced all taillight bulbs Current owner 110k Stoptech pads Greased Slider pins Front Sway Bar endlinks and bushings. Turbo blanket, black heat shield and down pipe blanket. Intercooler clean Fresh engine grounds Replaced Cobb poly shifter bushings with OEM for less NVH. DeTune - 91 octane Cobb OFS, running 93 octane 115k Sony AX100 double din LLumar Ceramic Tint Michelin Pilot 4S 225/45/18’s Driver side wheel front bearing Driver side NAPA caliper Brake bleed Uppipe thicker gasket. Rust prevention sprayed underbody. 120k Passenger rear wheel bearing Trailer hitch 125k IP&T oil screen removed Battery replacement Driver side headlight bulb - Daniel stern lighting 130k AC belt tensioner pulley and bracket Fluidampr crank pulley 132K All new brake hard lines, subaru recall WQK-47 -$2400 Grimspeed Brake Master Cylinder Brace SS Brake Lines Rear rotors Driver side rear wheel bearing Includes OEM floor mats Thule Roof Rack Bars Extra parts Extra set of It OEM wheels with winter tires. Edited March 18, 2021 by 03LegacyLE Price! Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted March 13, 2021 Share Posted March 13, 2021 Nice wagon. Maybe I'm missing it but is the asking price listed? Seems you edited the price in as I was typing. Link to comment Share on other sites More sharing options...
Kojak Posted March 14, 2021 Share Posted March 14, 2021 Mods may move you over to the car F/S thread. Otherwise, well done. Sophisticated like a light saber in a world of blasters. Glws. Link to comment Share on other sites More sharing options...
03LegacyLE Posted March 15, 2021 Author Share Posted March 15, 2021 Mods may move you over to the car F/S thread. Otherwise, well done. Sophisticated like a light saber in a world of blasters. Glws. Thanks, much appreciated. Added some more interior shots yesterday. Link to comment Share on other sites More sharing options...
ammcinnis Posted March 16, 2021 Share Posted March 16, 2021 (edited) Moved thread to proper Marketplace forum. Note: ALL photos must be uploaded to the Forum server, not linked off-site. You have 24 hours to bring your listing into full compliance with the Marketplace rules, else it will be removed. Edited March 17, 2021 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
03LegacyLE Posted March 17, 2021 Author Share Posted March 17, 2021 Security token issue won't let me upload images... Link to comment Share on other sites More sharing options...
ammcinnis Posted March 17, 2021 Share Posted March 17, 2021 (edited) Security token issue won't let me upload images... It's still your responsibility. You may need to resize your pics. See: https://legacygt.com/forums/showthread.php/load-pictures-and-files-sites-server-251315.html?p=5366891#post5366891 (which you should have already read). 24 hours. Edited March 17, 2021 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
03LegacyLE Posted March 18, 2021 Author Share Posted March 18, 2021 It's still your responsibility. You may need to resize your pics. See: https://legacygt.com/forums/showthread.php/load-pictures-and-files-sites-server-251315.html?p=5366891#post5366891 (which you should have already read). 24 hours. Just fyi all the pictures were all smaller than the required specs and files sizes. The work around, size the pictures MUCH smaller, 800px in my case and upload each file one at a time vs multiple uploads at once. Link to comment Share on other sites More sharing options...
ammcinnis Posted March 18, 2021 Share Posted March 18, 2021 Thanks for persevering. Good luck with your sale. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
hp12c Posted March 18, 2021 Share Posted March 18, 2021 Your car looks terrific, PM sent. Link to comment Share on other sites More sharing options...
whitexc Posted March 18, 2021 Share Posted March 18, 2021 Very nice, well documented wagon. GLWS. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
03LegacyLE Posted April 2, 2021 Author Share Posted April 2, 2021 Sold! Perfect owner got the car, it's in good hands. Thanks for all the positive comments, I loved the car through and through. Hold your cards if you have a clean one, they are going up! Link to comment Share on other sites More sharing options...
hp12c Posted April 2, 2021 Share Posted April 2, 2021 It was so nice to meet you 03LegacyLE! The buying experience was a pleasure and the trip home was a blast in such a well-sorted wagon. Here's to many years of happy ownership! Link to comment Share on other sites More sharing options...
